Infra Red Tire Sensors
Started by maguromic, December 12, 2012, 03:33:20 PM
maguromic
There are 11 infra red Cosworth electronics (Pi Research) F1 quality tire sensors upgraded with 5 pin male MS connectors and a front of car wiring loom with female MS connectors. You can cut up the harness to fit your needs a or use it as is. These are compatible with most data acquisition systems and came from an ALMS team and are spares that I don't need.  I want $650 for all of them, which is less than the new price of 1 sensor with the MS connector. Tony
