Nylon ties
Started by Truckedup, May 21, 2013, 04:26:27 AM
Truckedup
 Nylon ties, "Tie Wraps",we all use them. I know they are not to be used to support heavy stuff...But are they of for securing control cables like clutch and brake? By secure I mean guiding or grooming the cables so the don't flop around and leave enough flex so the cables don't bind when turning. The cables shown here on my bike will work ok with no ties but flop down....The tire looks closer than it it in the photo.
Graham in Aus
When I first came to Aus, I asked about Tie Wraps and where to get them etc.
Blank looks all round  :?
Then after some Pommie / Aussie sign language I got it:
MAAATE you want  "CABLE TIES" !  :cheers:
I better not tell you about buying thongs, that's a whole 'nother story!  :-o
Truckedup
 I'ma retired electrical contractor,cable tie is  correct.   But that don't answer my question........ :-D
Joe Timney
Yes, you can use them.
Joe Timney
Retired President of ECTA
www.delawarechassisworks.com
"Ty-wrap" is a brand name for the nylon cable ties.
saltwheels262
is that a mechanical tach on the right side of the pic?
I install gauges with hose clamps also. with strips of inner tube between gauge and clamp.
leaving Henderson
ohio -    - 185.076 w/#684
lta 8/14  - 169.xxx. w/sw2
'16 -- 0 runs ; 0 events
                            - franey  8/2007
Truckedup
Quote from: saltwheels262 on May 22, 2013, 05:47:23 AM
leaving Henderson
  Yes, mechanical tach and oil pressure guage. The hose clamps are brazed to the steel mounting piece. I use a closed cell neoprene foam sold on Ebay for a few bucks. The foam is also great for battery vibration insulation
LSR Mike
In Kentucky they call them "Chicken Bands"
Mike M.
BNI/ECTA
In California they call them hand cuffs :-D
Captthundarr
they can also be used to make a gelding. :-o
Anything that you life depends on that can be exposed to fire should be restrained by some thing more fireproof.
I've got some stainless tie-wraps.  Don't know where they came from.  Would last longer in fire than the cable surrounds, I think.
Captthundarr
Quote from: Stan Back on May 22, 2013, 06:24:16 PM
You can get a couple of sizes at most parts store that sell header wrap.
saltwheels262
Quote from: Truckedup on May 22, 2013, 07:30:22 AM
leaving Henderson
I have found I need rubber washers between frame and chain guard mounts also.
                            - franey  8/2007
Truckedup
Quote from: wobblywalrus on May 22, 2013, 05:02:56 PM
  I have stainless ties in the shop. I'll use them on the cables so it's looks a bit less hillbilly that it is..
