Smoke Generating Setup,,
Started by stay`tee, June 17, 2013, 12:20:49 AM
stay`tee
Need some ideas on how to build a gizmo to produce and deliver smoke for use in a small wind tunnel made to take 1:12 scale models,  :-),,
racefanwfo
How about one of the smoke kits they have for 1/4 scale r/c airplanes. Check at your local hobby shop.
The speed that you wish to achieve is only limited by the depth of your wallet.
Jon
How about a cheap smoke machine from eBay with a funnel over its outlet hooked to a small tube?
Underhouse Engineering
WOODY@DDLLC
Quote from: Stan Back on June 18, 2013, 03:42:12 PM
Lucas voltage regulator?
Smoke is too dark - can't see the model!  :-D
Signed, Prince of Darkness!
kiwi belly tank
Bob Drury
  borrow your kids Hookah...............................................   :roll:      .... just sayin................
Bob Drury
maguromic
Put dry ice and water in a 5 gallon bucket and then put a hole in the lid for a hose and pip it where you want the smoke to go.  Tony
stay`tee
some good leads there fellas, thanks, keep 'em coming,,,
its one thing to produce the smoke, but another to get a steady constant delivery at the wands end for a reasonable amount of time to be able to observe in detail whats happening in/with the flow, :-),,,
bbarn
Heat mineral oil.
kiwi belly tank
Tony's avatar is smokin!
Jon
rouse
Johnnie Rouse
floydjer
Won`t help you at all...But...when I was just a young floydjer, I soldered a petcock with a handle extension to a 5 # coffee can and screwed it to the firewall of my `63 Impala SS.. Hooked a hose to the intake manifold and filled the can with ATF......Good lord does that make smoke. :cheers: :evil:
stay`tee
its refreshing to know that im not alone in this cyberspace world,, ebay/DJ smoke machines,, not one single mention on here about 'em, :roll:,,,
tomorrow im gunna go and see a mate of mine who runs a party amplifier and stuff business, see if he has a good used unit he wants to get rid of, if not, there really cheap on fleabay, 8-),,,
