FORD, 9" N CASE, 2.75:! GEARSET WANTED
Started by THE ORGANIC GURU, July 01, 2013, 04:52:32 AM
THE ORGANIC GURU
Hi Guys,
Looking for a pristine 2.75:! matched ring & pinion for a 31 spline N Case setup.
Prefer new if anyone has one.  :mrgreen:
Thanks in advance for any help helping me finding it.
OG
RichFox
When I wanted 2.47s I went to the Ford dealer. Had them in stock. Been a while though. Did you try them?
SaltRat
2.47 and 2.75 are usually cheepcheep and plentiful at swap meets.  Seems everyone likes 4.11 or 3.73 so the tall ratios are unwanted.
N cases are not that easy to find . . . . new might be more timely.
Good luck.
SaltRat
When (if?) this baby hits 88mph, you'll see some serious poo.
Ron Gibson
As Salt Rat said. I bought a pristine 2.75 (open - needed for mini spool) 31 spline, third member delivered to my house for $50.
In my opinion, unless you are running huge horsepower and weight, the expense of an N case isn't needed for Bonneville.
YMMV
Ron
wheelrdealer
I think I have one. New Gears, maybe N case but could be cast. 31 spline, spool, 1350 U-joint. May have NASCAR V belt pulley on yoke. It would ship from South Florida. PM me if you are interested. I will pull it out of the box tonight and refresh my memory.
kiwi belly tank
You can't hook up enough on skinny LSR tires to need a Nodular Iron case.
I have a good used set of 2.75's I'd sell you for $35 + shipping.
