What exactly is an "Acorn" lug nut?
Started by SteveM, August 21, 2013, 09:26:54 PM
SteveM
I have always considered Acorn lug nuts to be the closed end type of lug nuts.
However, it seems that I have recently seen other descriptions, based on the shape of the lug nut.
I just don't want any surprises at inspection/tech.
I am using common (Summit), open end OEM replacement type lug nuts with tapered seats on steel wheels and OEM studs. (Record is 105 mph in my class).
Any clarification on the "Acorn" thing would help.
38flattie
Steve, you are correct-acorn nut is the closed end type of lug nuts.
Good luck!
http://www.flatcadracing.org/
http://youtu.be/89rVb497_4c
cagedruss
Captthundarr
Throw it in the lathe, cut the end off and it's legal... depending on wheel size and speed  :|
jimmy six
Lathe? Hacksaw!!!...make sure the threads go to the end. JD
RichFox
I drilled some through and ran  tap afterward. Few more threads can't hurt.
Geo Metro Racer
Quote from: SteveM on August 21, 2013, 09:26:54 PM
What class are you running in?
Ron Gibson
The open nut is required so the inspector can see the end of the stud to make sure there is enough threads in use.
Ron
dw230
Class doesn't matter, rule states no Acorn style lug nuts.
Quote from: RichFox on January 04, 2014, 03:04:44 PM
Rich, that works provided it's solid all the way through.  My Dodge came with acorn nuts, but they're simply a chromed aluminum cover over a standard lug nut.
I'd bet the anodized picture in cagedruss' response is the same.
