Springfield Flyer.
wheelrdealer
Exactly,
Move to the rear axle. A straight up project clears your head. Continue to ask and gather ideas and it will come to you. Sometimes you have to give the problem to your subconscious and let it grind on it for a few days, weeks.
SaltPeter
Hey Mikey
Remember to Breath.  :-D
tauruck
Hey Pete, Shoooo, I was blue in the face there for a while. :-D
You're right and thanks.
On the war path here but it's starting to take shape.
How much suspension travel do you feel like you have to have?
Richard 2
Mike, I'm no expert just looking at your project. What about building a top link like the lower one but shorter, to get your caster. Turn it in the opposite direction with the two links connected to the frame. May need to make the top connection on the axle a little taller and keep the upper and lower A-arms parallel. This mite make it more like a four link with out the panhard bar problem. Then I assume you are going to mount short coil over shocks in front of the axle. You can get them with a three inch travel.
It's just metal Cut and Weld.
Richard
4 cylinder Esslinger
Could of had a V8
tauruck
Thank you both for your input/advice.
I was going to run a pushrod suspension with the shocks behind the bulkhead but I've scrapped the side by side in favour of a tandem system.
I don't have pics yet but I am working on it right now.
It will allow me the swoopy body lines I wanted. My car was going to look a lot like Bobby Moore's Maro special but now I can give the nose a better aero profile.
I used a few design cues from other tandem liners along with my own ideas and I feel I'll only be building one version this time.
I wasted quite a few inserts and other bits on the failed designs but I can save them I guess.
lsrjunkie
Luckily Mike, I've never spent a bunch of time working on and idea, only to scrap it and start over!  :roll:
That stuff happens man! Good to see yer keeping yer head up and moving forward. If you have access to a lathe, recovering your threaded inserts is a lot easier than one would think!
Keep fighting the good fight man. You'll get it!
tauruck
#217
Thanks Joe.
I built the pushrod suspension on the truck in short time and it was cool.
This one??????
Guido is currently driving 450 miles to a classic car show in a Rover 90 that was built in the 50s. Brave dude. I was going to get to his spot to use the lathe this weekend but it will have to wait until Tuesday.
I've got enough inserts to go on with so I should be OK.
I spend December on my own with six Jack Russells because the missus goes to Scotland to visit her daughter. The plan is to get as much material and product together so I can work non stop for a month.
It's the summer holidays here and companies are closing by the hour so it's quite comical running from door to door trying to buy stuff you'll need.
I hope to put a big dent in this thing over the next month. I'm motivated and up for it.
Geo and I communicate almost daily and I made a statement this morning that is so true.
I'm in Africa building an American car and it's only happening because of this forum. Where else could I go to get all the help and advice I get here?. :cheers: :cheers: :cheers:
HOW much suspension travel are you trying to obtain--I do not remember this as being part of the discussion.
tauruck
Sparky, not much.
Maybe an inch and a half.
Ted Garstang from Bilstein and I go way back so I have the best of the best at my disposal.
Even though we live in Africa he is probably one of the best in the world at what he does.
I have quite a collection of Bilstein shocks here that have never been used so I might do a deal on swopping some for a custom set.
I do not know what speeds you are shooting for but I would sure be concerned about lift and roll in the range you are most likely shooting for.  Some type of leading arm or trailing arm suspension with 3/4" travel and adjustable bump stops maybe made like a lot of trucks have-- that are progressive rate one might even have the suspension made from them with you friends choice of shocks. This is a no engineers opinion but I have see the results of things that fly literally and not figuretively.  Body lift, asymetrical air flow, and angle of attack changes are not our friends above 2 .
tauruck
Sparky we're shooting for 450, just like George Poteet.
I'll post pics of my flying machine when it's done.
I started cutting the 9" to narrow it. So far so good.
Dynoroom
^^^^ Wondering what gear ratios (and other things) you'll be using with that rearend to go 450 mph?
tauruck
Gotcha!!!
I was hoping Sparky would reply.
450KPH. :-D :-D
Captthundarr
