Springfield Flyer.
Queeziryder
Mikey,
A good few years ago a friend and I stopped off to have a look round both parts of the museum on our way upto Gainsville for the AMA/Prostar dragbike finals (that dates it  :-D )
Whilst looking at Bo O'Brochta (Spelling ?) TF drag bike, who walks up but the man himself. He then took us round on a guided tour, and after finishing off the road vehicle museum he took us for tea with his mother who was still as sharp as a pin, way cool  :cheers:
Neil
Old enough to know better, but too interested in speed to care
tauruck
Neil, that's what humble guys do.
It must have been a great experience. Thanks for sharing it with us. :cheers:
tauruck
I have the first trailing arm for the tanden steer front end 80% done.
Some images of the  fabrication.
I built it on a jig but sometimes I forget to take photos. :roll:
I found a very good use for hard drive magnets. They need some sort of handle built on or they are difficult to handle.
tauruck
The welding.
Quite a few components.
I cleaned and cleaned just to make sure.
tauruck
The back.
tauruck
The uprights are also made up using quite a few parts.
The cylinders are actually necks I had from bike projects and will take tapered bearings.
tauruck
Boxed and ready to go to the engineering shop for facing.
The welding did a number on the backing plate.
It's got a slight bow in it even though I had it bolted to a 1/2" plate.
I should get them back on Friday.
Geo
Mikey,
Looking good. Must not be too hot there to weld that much!  :-P  You are living up to your tag line!  :cheers:
Geo
tauruck
The trailing arm in the chassis.
The slotted holes are for the caster adjustment.
tauruck
Thanks Geoff.
It looks like the rain has finally gone. There were stars out when I let the dogs out earlier. It's going to be a hot one I hope.
Two views of the trailing arm with the upright, spindle and hub. The proper parts are being machined but I just had to see what it looked like.
tauruck
I think the trailing arm needs additional bracing but I'm waiting for confirmation.
I was thinking to add a second tube above the one already there and one angled from the pivot point to merge.
tauruck
I love my job.
Whenever I have some new part in a mold It's like opening a Christmas present.
Even after all the years I still get excited.
The only thing thing is that even if you've been a good little boy you don't always get what you asked for. :-D :-D :-D
The composite Santa has a wicked sense of humor.
Glassfiber can be fixed if it's not great but the black stuff is a hit or miss.
I put more work into this water neck than it's worth but the OEM Ford was just a straight up tube on a flange so it needed to go.
A piece of useless info is that the flange on the Cleveland water neck is identical to the exhaust flange on a Harley.
That was the starting point.
Today I got to open a mold and I just know the part in there is a good one.
Some images. It still has the release agent on it but I love it.
tauruck
The flange will get two Aluminum inserts bonded in after drilling.
Two coats of clear and she's good to go.
I was up at 3AM for this one. :cheers: :cheers:
tauruck
Quote from: Geo on December 30, 2013, 06:48:21 PM
Mikey,
Geo
Check it out. What do you think?.
Mickey,  I would get one of the engineer types to give their opinion but I would want some extra thought on your system---there are some very complex stress going to be induced into that part!
