565" Injected Alcohol, Crower Clutch, T-10 trans
Started by bryanbrown, November 15, 2013, 03:43:26 PM
bryanbrown
565" Chevy injected on alcohol
Dart Block with water
4.60 bore, 4.25 stroke
Manley Rods
Callies Crank
11:1 compression
Isky cam – RR-654-Int, RR-727-Ex
Top Proline aluminum heads with water- 320cc Intake Runners
Jesel Sportsman shaft mount rockers-1.7 ratio
Manley 221444P Springs
Enderle 80A-1 fuel pump
Edelbrock tunnel ram
Birdcatcher hat
Enderle barrel valve
Stewarts Components 55gpm electric water pump P/N E558A
MSD 6A with rev limiter box
Weaver 3 stage belt driven dry sump pump
Zoomie headers
All fuel lines, nozzles, etc.
Dry sump hoses and water lines is all that's needed
Comes with tune up info
It's still in the car and can be heard if desired
Motor was in a aa/fmr and has 10 licensing runs on it that were all taken pretty easy: 7 at El Mirage (177mph max) and 3 at Bonneville (212mph max).  It only saw full throttle on one or two of those.  We're selling because next year we're putting an injected nitro motor in and don't have anything for this one to go in.
$14,500
Crower aluminum 10" 2 disc pedal clutch.  Chevy bolt pattern, with ring gear on flywheel.  New facings installed before Speedweek this year - $1,750
Tex T-10 Trans with Long Shifters HB-1000R shifter
1.64, 1.24, 1.0, .89
$2,000
All located in Gainesville, TX
Email is the best way to contact me
Bryan Brown
bryan@empireironworks.com
(979)492-8234
