Anyone using Flow-Viz paint?
Started by SaltRat, November 25, 2013, 10:28:00 AM
SaltRat
or anything similar?  what where how, please and thank you!
If you don't know about it yet, I like dark Mexican beer.
SaltRat
When (if?) this baby hits 88mph, you'll see some serious poo.
JR529
No, but I have used El Mirage brand Flow-Viz dust.  :cheers:
SaltRat
Bwahahahaha - I was once told that those in the know don't clean salt off the cars . . . .
SaltRat
Dynoroom
Rick Byrnes
Rick
I wonder were the F1 guys get that florescent green stuff they use. Probably really expensive!
Rick, what weight oil do you use?
Tman
Contact Marlo, they used some on the Target 550 model.
Dean Los Angeles
tauruck
I use the pigment that is used in flowviz.
It glows in the dark for hours too. I'm a lure builder. The stuff is expensive but it will last for a long time because you don't use more than a teaspoon at a time.
I think if you mixed it with oil you might have your own flowviz.
Rick Byrnes
REX
Racing oil of course....
Actually, I used what I had around which was 50 wt Mobil 1.
I think it shouldn't matter too much, but assumed that more viscous would be better.  Not a whole lot of experience with it.  Sample size 1of 1
:-D
Rick
SaltRat
SaltRat
Just looking through the latest issue of "Race Tech" and came across the F1 recipe for "flow vis"
I quote: " The substance is based on an organic solvent (usually paraffin or kerosene but it is possible to use heavier oils) mixed in approximately 3:1 ratio with pigment. This can be anything from Titanium Dioxide to lamp black to fluorescent colored chalk, Anthracene or Chrysene can be used to make the mixture -fluoresce under UV light and up to 10% of Oleic acid is usually added as an anti-coagulant. "
So there you have it the stuff that you see on the F1 cars.
dw230
That's exactly what I thought the Flo Vis was composed of. This opinion from a HS Chem class with a grade of a hard earned C.
hotrod
Used motor oil works great. Just place on car body in drops about half the size of a penny and drive 70 mph for a mile or two.
These were some oil tests I did on my WRX on I70. I would stop on the entrance ramp shoulder, put the oil spots on the body, then flog it up to 70 mph and pull off at the next exit (usually a mile away outside of town) and take the pictures. Wipe the oil off, then turn around, apply new oil and head the other direction back to the original location.
hotrod
Part 2
