Modified HP needed for a Speed Spreadsheet....
Started by Sumner, December 20, 2013, 08:05:26 PM
I modified the spreadsheet where if you know the HP to run a given speed you can enter a new speed and it calculates the new HP needed for that speed.
In addition to the above now you also have the option of entering a new HP level and it will give you the new expected speed at that HP level.
To use the spreadsheet download it and then save it once and you should be able to then enter data into it.
You can find it at the following link with the other spreadsheets I have....
.... or by downloading the attached file below,
