New Roadster Class
Started by Stan Back, December 25, 2013, 12:14:22 PM
Let's all get on the bandwagon (circus wagon?) and pitch in to get a new class in the Gas Roadster category -- Roadster Sidecar classes.  Maybe even more useful than the recently-new Compressed AiR Roadster class (C/AIR).
See illustration herewith . . .
Oh well -- it won't post.  Says it's too large, but it isn't.  I'll send it to the good doctor and maybe he can post it.
Quote from: Stan Back on December 25, 2013, 12:14:22 PM
I haven't seen the picture, but if a side car will help keep a roadster pointed in the right direction . . .
well . . . that might take some of the fun out of it.
Stan, I would think one of the class requirements should be the sidecar roadster must use a motorcycle motor... and the largest class would then be F not C.... The big problem is those smaller classes... can you imagine how long it will take a 50cc sidecar roadster to get to the traps  :-o
Open another box of wine...and we will talk about this more  :cheers:
Time that it takes to get through the lights shouldn't be a problem, Stainless.  The new class is designed specifically to run on the Course #7, which  is the perimeter road between the salt flats and the interstate.  The lights will start with one 300 yards from the start line, followed by another (making the first timing trap) at 325 yards.  The final light (there'll only be one "real" timed section will be from the 325 all the way down to the 500.  That'll make conversion from time to MPH pretty easy.  All the timer will need to do is relate the distance of 175 yards to miles, which is simply multiplying time by .00994318 or something.
Got it?
Stan you aren't you 107 days   correction 106 days early??
I'm trying -- I'm not lion!
John Noonan
A Turbo Hayabusa powered sidecar/roadster sounds great! :-D
Quote from: John Noonan on January 04, 2014, 08:57:48 PM
Right down your alley... I'm sure the Noonan Moreland team could have one together by April 1st  :-D
kiwi belly tank
I would like to see a trailer addition to every class. Like AA/BFS-T.
Ok.... I know what you're thinkin!! The chutes will get tangled in the trailer so they could go "on" the trailer. :-D :-D
4-barrel Mike
Would that trailer have its own engine and "driver train"?
kiwi belly tank
Only Streamliner & Unlimited Diesel Truck can use more than one engine. Rule 2.A.
Let me diverge from the roadster discussion and ask about the Ultd. truck class and the engine Carl Heap had in the Phoenix, and I think the Joint Venture Freightliner has one, too.  It was billed as a "16V72" Detroit Diesel.  To my knowledge that engine is a real single engine -- that's comprised of a pair of 8V72 engines back-to-back.  It was relatively common to use the big 16-cylinder engine for stuff like go-karts and mini bikes and - - what?  You're kidding -- that isn't what the engines were in? :roll:  Sorry.  I've been led astray.
Back to the 16V72.  Since it was a pair of 8's bolted into one, and since it was available from the factory as a 16 cylinder -- is it considered one or two engines?  Obviously I don't have a reason to ask other than just for the sake of knowledge.  Any certain knowledge on this?  Thanks. :? :-) :-D
RichFox
I thought the 16-71 and 16-92 engine was a true 16 cylinder block and crank with 4 of the 8 cylinder heads and two intakes and what not.
Rich, I yield to your greater knowledge of the engines.  Now that you remind me -- I think that indeed, I should have said 16V92.  Maye the "2" in that label is what caused me to modify the 71 into a 72.  Whatever, I'll go with your idea 'til someone comes along with definitive proof.  Thanks.
Maybe I'll go Bing-ing and find out what I find out. :?
I've found some stuff.  The 16V92 is the biggest model available in the 72 cu in/cylinder size, which runs from 4 through 16.  Taking a look at the engine's line drawing I see what might have got me going in the wrong direction, though - - there are four heads, just like Rich said, bolted onto one block.  The two heads end-to-end threw me off track, into thinking that a pair of engines was tied together.
Interesting is that the 1472 cu. in. engine is rated at 1350 hp at the shaft at "maximum" and 1254 hp at "intermittent-maximum".  But neither of those numbers is enough to power the Phoenix or Joint Venture to well over 200.  Anyone remember if there were/are estimates of the horsepower output of either of the engines?  We can go back to sidecar roadsters if you'd like, by the way. :cheers:
kiwi belly tank
It gets a little confusing if you're not a Detroit guy.
6-71 is an inline 6 with 71 cubes per cylinder. A 6V-71 is a V6 with 71 cubes per hole.
There is both a 12V-71 that is one block/crank combo & one that is two V6's together.
71 series engines were available in 1-2-3-4 & 6cyl's as inline.
The 92's come in V6 & V8 & the The 12V & 16V engines are doubles from the factory.
The 12V-149 & the 16V-149 are single block single crank.
In fact the turbo's on my liner came off a 12V-149.
