54-55 331 HEMI heads
Started by SPARKY, March 26, 2014, 01:08:01 PM
I am trying to find some of these for someone:
54 # 1486833-1
55 # 1556157-1
dw230
Tom Sauter Bonneville 2 Club member
TNT Hemi Engines
928-412-4049
pg 234 in your rule book
Sparky --
I've done a little research to no avail, but I believe those two casting are quite different.  I'm no Hemi expert (only got one), but the I believe the '55 has quite a different port configuration.
(So no help here.)
Stan
anthony young
sparky, i run the 1486833-1 on my roadster they work well on fuel they are the 1954 331 head when ported properly :-D and welded at the heat riser they will out flow the race style hot head.  anthony young
That shows how much I know -- I thought they were the small port early heads.
desotoman
Quote from: Stan Back on March 26, 2014, 05:58:18 PM
Stan,
Small port early heads were 51-53 extended bell-housing motors.
Sparky,
The 1955 # 1556157-1 are known as the triple nickle heads and they are the heads everyone wants so they command big bucks.
jdincau
That was the hot ticket in 1962, 354 heads with 392 valves.
Called Tom today---he has both heads he was about to leave will be back Tuesday---  he should be able to hook me up---he said the main difference was the 555 had water ports in the end of the heads
I need a "Cut up head" for my "head guy"
If any one has one of these that is ruined please let me know
ATS, Inc
Did you try Albert Eshenbaugh, I know he runs early Hemi motors, and he has been known to wound them once in a while!
I see Al all the time, he is on the way to my steel supplier,  only problem Al is now a Lakester owner :roll:
GH
Sparky, I sold a whole crate of hemi stuff quite a few years ago to a guy who owns Willys Replacement Parts. He is some where in CA. If you want I can probably get you a name and number.
tauruck
Quote from: SPARKY on March 31, 2014, 09:53:27 PM
The hits just keep on coming. :cheers: :-D
