Clutch ?
Started by Fheckro, May 16, 2014, 03:46:10 PM
Fheckro
I am shopping for a new clutch. I have dun  graduated to 600+hp...wah hooo!  but the old street clutch will no longer cut it.
I am considering the Ram Force 10.5 double disc
http://www.summitracing.com/parts/ram-80-2100n/overview/make/chevrolet
Any suggestions?
Fred
9479 Monza C/CGC
Current record Holder @ 180.000
Momec
After using several diaphragm style clutches and ending up with slip in varying degrees my next clutch will be a long style that can have centrifugal weight added. My last vehicle was an F100 with 650hp and it slipped bad at 184mph.
Chris
Acme Racing #251
XP Falcon Ute 174.651mph
82 F100 C/PP record 184.985mph
AU Falcon Ute D/PROU record 178.998mph
Lake Gairdner Aust.
Chris;
What type of friction material were you using on your diaphragm clutch disc? A Long style clutch with added weights can be almost impossible to disengage at high RPM.
jimmy six
Double disc 10'000 RPM clutch from Ron Hamel ( deceased) Lancaster Ca. Handled 750 HP GMC on 75 % nitro with out problems. 2 disc is the way to go.......good luck.
Momec
Neil, I used the ceramic style friction material.
Trans is a Doug Nash so plan to only use the clutch of the line.
Chris
Acme Racing #251
Lake Gairdner Aust.
Chris;
Hmmm... I would think that clutch should have handled your torque. One thing-- diaphragm clutches are sensitive to how far their fingers are deflected. If it was ever over- deflected it would have been  damaged.
mike f
 Depending on how much you want to spend a 3 disc 71/4" clutch will work just fine.  I know of  few high HP cars using even a 5" 3 disc.  You can find rebuilt ones because of there wide use.  No matter what type of clutch you use ALWAYS install a pedal stop.  You never want to go over center with a clutch.  Mike
Momec
Over centre stop. Probably what I neglected .
Chris
Acme Racing #251
Lake Gairdner Aust.
