Seat inserts
Started by Buickguy3, June 04, 2014, 06:05:57 AM
Buickguy3
   I saw this and was wondering if they would pass it in tech on the Salt? I've seen something similar in other forms of racing. Looks like you can buy the stuff in kit form. Not that I could afford the stuff, it's probably pretty pricey.
      http://www.realequipe.com/
                   [America]
maguromic
I have used this system and and walked away from a horrific crash.  The cost of the  system is very reasonable  and easy to use.  I am going to use the same on my roadster unless someone tells me I cant.  We are also using it as an immobilizer to pull the driver out with it in an emergency. http://www.baldspotsports.com/   tony
JamesJ
There are others using these type of inserts and have not had any trouble from tech.
Here is another company that does pour in place seats   http://www.ispseats.com/
