Dry sump question
Started by Rocket123, July 16, 2014, 08:27:40 AM
Rocket123
First time with a dry sump. A rather expensive lesson trying to make wet sump work. I thought I bought a 4 stage pump but it is only 3 wanted to run 3 to the pan and 1 to the valve cover. What I am wondering is if I could split 1 line probably the one going to the front of the pan and run it to the breather also. help is appreciated.
Thank You, Rocket
http://www.saltsurfers.com
Nothing succeeds like persistence. I hope!
another option might be to plumb the valve cover lines to the pan or to the fuel pump block off--
-no matter what you do--the stage you split is going to feed from the path of least resistance
I would just take a stage upstairs, if you feel like you have to-- but I have no personal knowledge, of going upstairs with a stage---
I run a four stage just like you with 3 on the pan and 1 pressure  I make sure it can drain back as well as I can get it to and just run 16 quarts at B'ville
Rocket123
sounds like I didn't know how to count stages and I do have a 4 stage pump 3 scavenge and 1 supply. plumbing the valve cover to the fuel pump block off plate sounds good to me, any other input welcome.
Thank You, Rocket
Bob Drury
    I am assuming that you intend to seal off the lifter valley and suction the upper end oil back to the pump.
   I would suggest that you pull a AN 12 from the valley and tie it into a AN 10 from the front area of the oil pan.  If the pan already has a AN 12, use a reducer.
   On the other hand you don't want to pull any more air than you have to into the Dry Sump Tank.  Make sure your tank has a anti-aeration screen in it.
   On my BBC, I mounted the magneto in front and built a 3/4" copper manifold which lays tight to the lifter valley and is "hung" from the bottom of the intake manifold
   and runs from front to back and then turns up thru the now vacant distributor hole terminating to the An 12 line.
   Don't forget to run inline screen filters on each suction line BEFORE the pump and a Big filter on the pressure side of the pump.
        Bob Drury
Bob Drury
Bob brings up a good point---what are you trying to accomplish?
HP or removing oil from up stairs?
Rocket123
basically what we are trying to do is control blow by out the valve covers. our lifter valley is not plugged off. we do not want to put more air into the tank. maybe with a dry sump there isnt as much blow by. Would it still be a good idea to plumb the valve covers to the fuel pump block off plate.
Thanks a lot, Rocket
#6
 you want to create a vacuum---and you should the whole eng should be sealed so that it can pull a vacuum---if you have a leak you are just going to move the blow by to the dry sump tank---my lips are sealed as to why I know this first hand---it does create NEW problems  :-D
Rocket123
got it. valve cover breathers sealed and 3 scavenge lines to the pan. TY
Ron Gibson
I started  to do the same thing (sealing engine). Then thought about what would happen if it holed a piston. I can visualize the pressure blowing out valve cover and pan gaskets and oil on the headers with it. Check valves on the vents should let a vacuum be pulled and still release excess pressure.
YMMV
Ron
one of the benefits of dry sump---there is very little oil other than in the sump tank---I have not burned a piston yet---but mount a vacuum gauge to the pan lifter galley area---if you start getting blow by you will know it before it blows--- if you have an idiot light on the PAN vacuum or happen to be watching the gauge rather than the track!!  :-P
Ron Gibson
Not meaning to argue with you, Sparky.
Aviad says BB Chev flows about 12 gallons per minute at high RPM. That's about 25 ounces per second that's being thrown around in the engine. To me that is enough oil to make a mess. :-(
Ron
fordboy628
A vacuum gauge connected to the engine valley/sump is an essential item to properly develop a dry sump system to "evacuate" blow-by.   Don't be surprised if it takes WAY more pump stages or capacity than you think to create a vacuum.   You will need to reverse your crank seals (think about it . . .) OR run seals with a "dual-lip".    High levels of vacuum create strange sealing problems within engines.    Think carefully about using gaskets Vs. a sealant, ie: RTV.
Serious reduction of the internal "oil mass", MAY create weird wear issues within the engine.    Be sure to do a thorough evaluation of components & wear patterns during teardowns.   This is VERY important and should not be ignored.
BTW, some engines respond very well to this, others just don't seem to respond with any bhp pickup.
Check out a current WINSTON CUP engine, IF you can get close enough for a picture.   Dismiss publicity photos, NOBODY gives away ideas at that level.   CUP engines circa 2002 ran 5 stage pumps, 4 scavenge & 1 pressure.    And all sorts of oil flow reduction.    These engines had 0/1% hot leakdown and pulled at least 5" of crankcase vacuum.   Consider for a moment that in 1992 the same engines had 4/7 cfm of dynamic blow-by at WOT on the dyno in the power range . . . . . . .
Think seriously about blow-by reduction in the first place.    Blow-by is LOST combustion pressure, ie: horsepower.   Do what is necessary to get it sealed up.
Rocket123
Does it matter where I put the oil tank, how far can the pump pull the supply oil? Thank You
Rocket123
also any suggestions on line size was going to use 12an supply with 12 an scavenge to the pump and 16 an from pump to tank. Thanks again
