motorcycle tires
Started by gman7, July 18, 2014, 03:37:38 PM
gman7
I like to get some opinions on rear tires for the salt: obviously they have to be rated for the speed you are going, are there any advantages of radial, bias, slick or bobby threaded tires for the salt?
No big deal - radial or bias - from my experience.  Slick versus treaded?  Again, no big deal, although the less distinct tread patterns will be a bit less likely to heat up excessively - I think.
But first of all -- your tires are not just to the speed you'll be running, but to the speed of the record in the class you're going to run.  If your bike will only go 130 but you're running it in a class where the record is 205 -- you'll need tires that'll meet the 205 number, not the 130.
gman7
Quote from: Seldom Seen Slim on July 18, 2014, 06:29:39 PM
Got it Jon, thanks
