Stream liner length
Started by debgeo, July 30, 2014, 10:13:15 PM
debgeo
I see a big difference in length of streamliners. Is length determined by area needed or does longer length help aerodynamicly ?
George---Sidecar in progress
John Noonan
John has just about said it----Packaging is everything---if you try to use "normal" stuff you will end up being pretty big if you are trying to use big HP---downsizing COSTS
kiwi belly tank
My liner builds have always been about packaging. To get a small frontal area & fit all the crap in, they tend to get long. My new liner came out at 40ft & that created some transporting issues.
tauruck
Quote from: kiwi belly tank on July 31, 2014, 07:51:41 AM
You think??????
Sid helped me when I started out. I still know squat but he was right on the money.
Packaging is a little understated. :-D
#5
lol
"Packaging is a little understated.  grin"
I encourage you to build something that can be changed fairly easily--
You most likely will be changing things---I have run my new car twice.
We are in the thrash of an axle change and axle mounting change modifying the canopy-- lots of wiring change and rerouting, hood scoop modifications.  Once we find out what "Ms. Liberty" likes and dislikes we will then really try to build a nice final version ---with PAINT!!
We rebuilt RATICAL, nearly completely 3 times, before we got a  car that could handle the HP and the race course---hopefully it will not take 3 rebuilds this time around!
I say this, because (IMO) if you build a really nicely finished car you are a lot less likely to start cutting and chopping to make changes, you may need to, or try new ideas.
My thoughts are get a GOOD race car---FIRST--- then try to spiff it!
As they say YMMV   :cheers:
dw230
When building any car you must keep maintenance in mind. If you have a tightly packaged design, tanks laying on top of each other for instance, plan on which ones can be removed easily and more often. Is the engine set back? How do you get a head off without unbolting the engine. Do you have a fully belly panned car? How to easily do bottom end maintenance without complete disassembly?
It goes on and on ...
John Burk
Ron Ayers said above 300 mph over 70% of the aero drag of a streamliner is skin friction . That says minimizing the surface area is worth more that minimizing the frontal area . A 3' x 3' x 10' box has the same volume as a 2' x 2' x 22.5' box and the 10' one has 2/3 the surface area .
kustombrad
But at 300mph do you want to be in a 10 ft. long box or a 22.5 ft. one?
kiwi belly tank
I too am having a problem seeing how a short fat liner could out perform a skinny one. Anybody have any pics of a "short" Ron Ayres design? :roll:
John Burk
The wheelbase of the Black Salt Triumph is 130 inches .
kustombrad
That Triumph isn't really a streamliner but we'll do a quick comparison anyway. It went 380mph with roughly 2000hp and it's pretty short and fat. Speed Demon is roughly 35ft long (obviously more surface area) and with the D motor (a little less than 2000hp) it went 420mph. Not really apples to apples but part of that theory doesn't really fly (even if it's technically correct) or streamliners would still look like they did in the 60's.
tauruck
Brad, you built it long and you know why. :-D
John Burk
I agree , with it's high drag , high frontal area and 50/50 static weight distribution Black Salt is a poor comparison but the difference wasn't handling . It would sound silly if somebody proposed a 130" wheel base top fuel dragster but that's what funny cars have .
kustombrad
That's actually a cool thing to bring up John! Since a Funny Car is all about aero since it's short wheelbase doesn't allow as much clutch as a TF (the longer wheelbase transfers better) car. Kinda makes you wonder (if you detuned it to actually hold up) and ran them both to 1/2 or 3/4 of a mile if the FC would actually have an aero advantage and make it have a higher MPH being both shorter and wider?! Sorry to get completely off track there...
