Non Standard piston Rings
Started by real norton, July 31, 2014, 04:26:55 PM
real norton
 I need rings for custom pistons
Looking for USA Supplier
Any suggestions?
Thanks Carl    Real Norton
Total seal should be able to help you.
http://www.totalseal.com/
For future reference, it's often easier and quicker to get custom pistons cut to an existing ring pack than to go the other way around.  :wink:
4-barrel Mike
I'm reasonably sure that the bore on my brand new block was decided on based on ring pack availability.
Ron Gibson
What they need is a book listing by specifications only. My Bow tie needed a clean up bore. No CHEVY rings for a 4.390 bore. Ford 460 ci oversize rings are that size. Problem solved.
Ron
Try this page.
Provided your ring thickness isn't odd, or that your pistons couldn't be recut to accept them, this lists their ring packs by diameter -
http://totalseal.com/SearchByBore.aspx
real norton
  Thanks MM
I will be making compression chamber and piston casts soon so I can send them to some manufactures for
pricing   Thanks Carl
