Non contact torque sensor:
Started by Rex Schimmer, October 28, 2014, 01:43:09 PM
Just ran across a very interesting device, it is a non contact torque sensor that will work with any steel (material needs to be magnetic) shaft including hollow tubing (think drive shaft) to provide real time torque readings. With one of these you could make your car into a real time dyno. This is their site: http://www.tam-sensors.com/active-2-sensor-kit/. Doesn't take much thinking to see what sort of possibilities a device of this type could bring. I do not know the pricing ( I have requested that info) but I am sure that some of the more well funded efforts could probably afford one. Instant info on whither that last tuning change helped or hurt your horse power!
dw230
AEM has a similar device known as a drive shaft dyno.
Dynoroom
You might find that these multi-time record setters also use this type of technology. Probably have for over 10 years.....  :-)
Mike,
Why does that not surprise me? Probably one of the most tech and out of the box thinking group at the salt!
It is possible to build a torque- sensing system yourself. A front- engine car can use its drive shaft twist to measure torque.
Install an anti- lock wheel sensor on the front and rear of the drive shaft and measure the time difference between the pulses. The drive shaft will twist in proportion to the torque that it is transmitting. The twist must be calibrated. Also, the measured torque varies with the transmission gear ratios of course, so to get engine torque you must divide the measured torque by the tranny ratios.
fordboy628
About 15 years ago (light years really) I was involved in a project to validate engine bhp of rebuilt armored vehicle engines using then new, no contact torque sensing data collection.   As far as I am aware, the process is still being used, still very "confidential".   The pay was great though . . . . . . .
POPS
We developed a torque sensor for T/F about 15 years ago. The unit interfaced with a ProII Racepak. We instrumented the Female/Female coupler with straingages. The power to the sensor and the strain signal back were all done with RF. The good news is the info was really useful. The torque curve followed the clutch controller curve. Around 4000 ft-lbs on the leave and 8000 on lockup. A spike of 11000 to 14000 ft-lbs was common at lockup due to the energy stored in the Goodyear flywheels. The bad news is we couldn't make the straingages stay glued to the steel because of the torque spike. I had to quit selling them because they would only last 4 to 6 runs. The project hurt my wallet. HP calculations are interesting, use 8000rpm.
Doing the numbers is pretty interesting. 8000 lb-ft @8000 rpm is about 12,000 + hp and at the 14,000 lb-ft spike it is 21,000+ hps!!! Now that is real horse power.
The TAM transducer is magnetic and does not require gluing on strain gauges so it might survive better.
