Motorcycle tires on skinny rims
Started by aircooledtechguy, November 10, 2014, 09:16:53 AM
aircooledtechguy
After seeing a couple cars at this years WOS running motorcycle tires, I have had a hard time getting this out of my head.  Clearly my staggered 6.5"/8" wheels with their corresponding 205/235 tires, while great on the street/track, are NOT optimal for the salt. :lol:
So I contacted my buddy who can narrow a set of Porsche wheels for me in hopes of running 17" motorcycle tires and he mentioned that motorcycles use a different bead seat on the wheels/tires.  :?  Huh??  So how did those of you that ran the motorcycle tires accomplish this on stock rims??
I've got a set of base model Boxster twist wheels that have the perfect offset to the outer rim lip that could be narrowed easily but why bother if tires won't safely mount. . .
Regards,
Nate M.
Anacortes, WA
Owner: ProVolks LLC
generatorshovel
Tiny (in OZ)
vwpsycho
We run 15x6 VW Passat steel wheels. We've used 23", 24" and 26" Goodyear Frontrunners up to 220 mph on a 3200 lb. FWD car with ~1000 lb on each drive tire with no issues whatsover.
Abe Potter
Salt Lake City
2571 G/BGC Volkswagen Passat
Kiwi Paul
Abe--Make sure you really look at those Frontrunners  each time you have run them. I Inspected a pair that came from a front wheel drive turbo car that runs in the 230 range, and they were not nice. Tread chunking, deformation and a case of Driver Shorts Fill....The better bet would be the correct Goodyears if you get the Passat going a bit quicker. By the way--I think I Inspected your car when you first bought it out. Nice Job..
36hplandspeedracer
Dewey and Abe run the worlds fastest four cylinder VW, their 2000 Passat. Like Kiwi said, it's nice.
Photo by Burly Burlile
Burly
dw230
That car is faster than Rick Yacoucci's 'Busa streamliner?
Speed Limit 1000
#6
Dan, He said VW :-D
dw230
Whoops, you are right John - I read too fast.
BobsVW
When I started my Bonneville build with my 1968 VW Bug, I couldn't find tires rated for the USFRA 130/150 classes. Ended up talking to BJ Burkdoll, the USFRA tech inspector. I'm using Hoosier drag racing front tires on both ends of my car...23" on the front to help drop the front end, and 25" for the rear.
Another racer uses motorcycle tires.
BUT, in both cases we are both using narrow VW rims...4.5".
Don't even think about using wide tires on the salt...Narrow is required/desired/the way to go.
fredvance
redhotracing
Quote from: 36hplandspeedracer on March 11, 2015, 05:48:11 PM
Burly
Isn't Das Bullet the fastest 4cyl. VW @ 246.xxx?
Love the Passat, BTW.
Luke- Winston Salem, NC
Loring 2 Club- 201.252 (2010)
Ohio 2 Club- 203.712 (2013)
Thanks for saying that, Fred.  I was going to say it -- but thought I'd let you lead the band this time. :evil: :evil:
dw230
I thought Das Bullet t a powered by Audi? Or are they the same company?
redhotracing
DW-
Quote from: dw230 on March 18, 2015, 12:15:24 PM
VW/Audi use the same (in Cosgrove's case) 1.8T motor... the only difference in
application use is sometimes Audi will put one in longitudinally for an AWD car...
I've had that motor in cars from each manufacturer; same thing... They can take
an outstanding amount of boost. A friend in upper NY has one sitting at 600awhp
in his 2001 Audi A4 Avant (WAGON)--- Talk about a sleeper!
DW- You guys are running a turbo VR6 in your MMP, right? Another solid motor...  :mrgreen:
jacksoni
Dan- I was wondering if this sort of name swapping in any way runs afoul of engine swap rules? Same engine but Audi and VW are clearly different critters, a least in some ways. Of course same problem with Honda/Accura and Nissan/Infiniti  etc.
Jack Iliff
G/BGS-250.235 1987
G/GC- 193.550 2021
G/GMS-182.144 2019
G/GCC- 194.580 2025
