ignition tester???
Started by entropy, November 22, 2014, 03:57:54 AM
entropy
My current issue is ignition noise contaminating data logging channels.
NA carb v8 with MSD ignition.
On Racepak advice, i moved the data cables as far as i could from any ign wires/components and it really helped
But i'd love to "cure" the noise and bench test electronic components like tach, shift light, rpm AND assure no noise is in the logging system.
Greg, my Racepak guy turned me onto an ign tester which apparently fires up the ign system without starting the engine:
https://www.southwestspeed.com/?sec=view_menu&cat=Engine%20Parts&sub=Distributors%20and%20Ignition&ssub=Ignition%20Testers
Does anyone have any experience or know someone who does with these type testers, i.e. MSD 8998?
It is time for me to go to ignition systems 101...
Karl
Dynoroom
#1
I have a MSD tester but me thinks your problem my be solid core spark plug wires? Buy the MSD anyway as you can use it to test when the rev limiter come on ( not just whats on the label) setting your shift light, matching tach to datal log rpm etc.
fordboy628
Quote from: Dynoroom on November 22, 2014, 12:24:26 PM
I have a MSD tester but me thinks your problem my be solid core spark plug wires? But the MSD anyway as you can use it to test when the rev limiter come on ( not just whats on the label) setting your shift light, matching tach to datal log rpm etc.
x2
My experience is that you can not run solid core ignition wires at all with data logging.
And it helps to have "shielding" for the data collection wiring.   Trust me on this, even a crank mag trigger can cause problems.
Check out the shielding on the ignition wires/magnetos on a WWII warbird.   No shielding = no radio talkie . . . . .   Primitive AND effective solution.
I dunno about MSD but Crane specifically says not to use solid- core wires plug wires with their HI-6.
jdincau
#4
Quote from: manta22 on November 22, 2014, 03:12:39 PM
Regards, Neil  Tucson, AZ
MSD says the same and to run the magnetic pickup wires away from any high tension leads.
AEM tells me to run the wires from the MSD box to the coil as a shielded twisted pair and far apart as possible from the data collection circuits.
entropy
#5
Guys,
Thanks much for the input!
1.  i need to understand how my current system relates to your advice:
a)  distributor/coil - p/n "MSD-8362" Street Fire HEI Distributor - Summit, $149.95
b)  ignition wires - MSD 8.5mm Super Conductor Spark Plug Wire" (red, 90 degree on dist & plugs), Summitt p/n 35599 (probably)
c)  spark plugs - ACDelco 19307139 Specialty Rapidfire Spark Plug - bought July 3, 2014
2. then figure out if any of that stuff needs to be replaced
3. then re-route/replace the wiring & switching as needed.
4.  then i'd like to test as much of the system as possible before starting the engine.  This is where the MSD tester 8998 or 8995 might come into play.
Dynoroom, you have that tester (which one?), have you found it useful?
I'll happily spend $190 on the tester if i know which model to buy.
I have the time and I have the desire, so thanks much for your input.
Karl
