2nd 100cc APS build
Started by sofadriver, December 16, 2014, 08:37:50 PM
joea
Mike, the change /adjustment to tail might possibly be one of those "blessing in disguises"
I honestly don't know how much of an effect the tail has on bikes, no certain how effective or in effective they are at reducing drag and or increasing stability
But...you will be adding surface area to the rear, and raising it, hopefully it helps with the air coming off you and the front of the bike
I think its common to assume it will help, but as with most assumptions it's a crap shoot imo, until proven out, there are a lot of bikes that are very stable with minimal tails, and nearly naked, and many bikes that are struggle with swoopy body's
At any rate, many find some gain in speed when butt raised a bit, your adjustment in height will be near that region, so hopefully this helps, you may consider an assortment of removable tail fin configurations that can be readily swapped out in your quest to find more speed
sofadriver
#181
Well, Joe, you may be right about the blessing in disguise.  We'll see.  This re-do is bringing me back to how it was supposed to be in the first place.
The multiple tail sections will have to wait for another year.  I've got a list of things to do as long as your arm and the clock is ticking.
Today after work I cut off that tire hump and cut an old 180/60 - 17 rear tire in half to slip over my little rear tire for the correct shape and clearance.  I'll have plenty of room now.  Fairing it in will be a challenge.  I'm thinking I'll hot glue both ends of 1/16th welding rods to the surface of the tail and let them bow around the dummy tire naturally.  That should give a nice smooth shape.  That's the plan, anyhow.  For now.  Maybe.  :|  :-D
Mike in Tacoma
Bike #833
joea
i wasnt suggesting multiple tails....only multiple fins, in case you had remorse or wondering about
the effect of going without the first one
sofadriver
Joea, I believe you were right about the blessing in disguise.  The new framework I've made is better and it's what I had planned in the first place.
I used 1/16" aluminum welding rod to make a "birdcage" around the dummy tire.  I let the rod make it's own bow shape and it came out really well.  Only problem is that the rod is so easily bendable I don't think I can tape directly over it without damaging the shape.  Steel rod would have been better but I had the alum. laying around.  I plan to wet out some 1" strips of glass cloth and just drape them over it to get some structural strength before I apply the skin.  I thought of using paper mache' but I'm worried it might turn to mush when I try to lay on the glass.
Mike in Tacoma
Bike #833
Mike, it doesn't appear that you've allowed for tire growth. It's an unfortunate fact even at relatively low speeds. You may want to check that out before you redo that glass. It would be a shame to have to do it again after the body was completed. Then again, are racing vehicles of any sort ever completed if they're serious?  :-D :-D :-D
sofadriver
The tire you can see is the old street tire I cut and slipped over the real tire. I also put little half inch blocks between them for more clearance. I'll have over an inch clearance above the race tire when done.
Mike in Tacoma
Bike #833
donpearsall
Mike, if you lay wetted cloth over the wires you will have to do a lot of filling to get it smooth (as you know). Why not use your spray foam to fill in the gaps between the wires and then sand to the wires, then do your aluminum tape trick?
sofadriver
Quote from: donpearsall on March 25, 2015, 08:50:32 AM
Yeah, I think you're right, Don. If I go acros the rods I'll link them together without disturbing them.
Mike in Tacoma
Bike #833
tauruck
Put duct tape or masking tape over the wires first and then glass it.
Take a more diagonal route, less sag.
sofadriver
I did the foam thing yesterday and it worked well.  I found that the technique is to hold the nozzle perpendicular and about 1" or so from the surface. That way the foam catches on the rods and then surrounds the rods as it expands.  I sprayed the foam in single strips about 4" apart.  After letting that expand and cure about an hour I shot more foam into the remaining gaps (about 1").   I came back today and trimmed it all down to the wires with my Fein tool and foil taped it.  Nice and sturdy. :-D  I'll glass it tomorrow.
Mike in Tacoma
Bike #833
Quote from: tauruck on March 26, 2015, 10:00:14 PM
Awesome job Mike. :cheers: :cheers: :cheers:
I was thinking the same thing. You did a really nice job of blending the shapes.
sofadriver
Thanks.  Actually the rods did all the work.  I can recommend this method when there's no good way to support the body form. Use steel rods, though.  Despite that, I'm not very happy with the whole top of the tail section but it will have to wait for next winter to be changed. (always gotta' have a project  :-D )
Me and the belt sander went at it hot & heavy today!  There's a few thin spots and burn-thrus but I've been planning to do some reinforcing from the backside anyhow - so no biggie.  All in all, I'm real happy with it.  When I got to the lower sections I rolled the bike on it's side to make things easier.  :evil:
Mike in Tacoma
Bike #833
sofadriver
Today I got to do a little of the fun stuff - rippin' and tearin'!  :-D :-D
Mike in Tacoma
Bike #833
tauruck
Weird feeling tearing up all the hard work hey Mike?. :-D
