2nd 100cc APS build
Started by sofadriver, December 16, 2014, 08:37:50 PM
maj
where were you looking when you thought of that ??
Great idea
sofadriver
#92
Quote from: roygoodwin on February 03, 2015, 08:30:09 PM
http://en.wikipedia.org/wiki/Catenary :wink:
Very interesting. How the heck did you know the word Catenary?  :? :-o :-D
Roughed in another nose rib then threw on a rough windshield shape just  for planning. I knew I'd have to "wing it" a little here but it's going to work out fine. I'll cut out a better version and use it to make a final rib that will set the shape of the top of the windscreen. I'll use 1/16" Lexan for the final windscreen.
Mike in Tacoma
Bike #833
sofadriver
Quote from: maj on February 03, 2015, 12:54:35 PM
Knowing me, I probably accidentally noticed a long strand of pearls hanging between two of my favorite things!  :cheers:
Here's another shot of the windscreen and one of the thigh rests. My kneecap is about where that line is by the axle. Once I'm on it, it's actually very comfortable. I'll have to be careful not to fall asleep.  :-D
Mike in Tacoma
Bike #833
Mike, is your bike's snout short enough to comply with the regs?  There are limits on how long it can be in many rulebooks.
sofadriver
Yep,  a full inch.  I have to keep checking with my framing square because it looks so close.
Mike in Tacoma
Bike #833
tauruck
Mike, you're putting in a lot of work there.
It looks good. :cheers:
roygoodwin
my college room mate was an architect student & I was a engineering student until I got to integral calculus  :-D
sofadriver
Got the final windscreen shape done today. The silver surround shows the bed that the Lexan will sit on. The black is the view area.
Mike in Tacoma
Bike #833
sofadriver
(I almost have to laugh when I see this  :-D)
How to adapt the reed cage from a Honda CR125R onto a Kawasaki KX100 motor.
Mike in Tacoma
Bike #833
fordboy628
Yikes!
My hat is off to Dr. Frankenweldenstein!
F/B
Old Scrambler
sofadriver
Got the lower-mid body shape cut, mounted and "mated" to the upper shape (whew!). I cut and mounted one of the two middle side panels (the only two flat panels on the bike). Note that the body runs all the way up to just behind the forks and the belly will end at a vertical line just behind the front axle. Since the front fender can be an inch wider than the forks (each side) I can make it so it actually overlaps the front lower fairing. The air should have smooth going as it passes from the fender to the lower fairing. That's the theory anyhow.
Tomorrow, I'll be using the "Catenary ball chain technique" (thank you, Roy  :-D) to determine the belly shape.
I really enjoy doing this. I call myself an "advanced tinkerer" so this kind of stuff is right up my alley.  :cheers:
Mike in Tacoma
Bike #833
sofadriver
first lower-mid side panel.........
Mike in Tacoma
Bike #833
sofadriver
I've finally made a final decision about the paint.  :-D :-D :-D
Mike in Tacoma
Bike #833
