Motorcycle speed in gears
Started by sofadriver, December 20, 2014, 01:30:28 AM
sofadriver
Been a long time since Algebra 1.
Can anyone change this around to find speed?
            speed x 336 x pri x gear x     big
RPM =                                            small
                            diameter
Thanks in advance
Mike in Tacoma
"aww, what the hell - let's just do it".............
Bike #833
100cc A/G, A/F and APS/G (in 2019)
stay`tee
mph = (rpm x tyre radius) / (primary x drive x final x 168),,   8-)
sofadriver
Quote from: stay`tee on December 20, 2014, 03:56:18 AM
Thanks, stay'tee.
Couldn't get that to work with the 168 (although 491mph would be coolish!).
Seems to work with 336, though.
I come up with 138mph and that works for me!
I've got more sprockets and more rpm than the figures I used.
But I'm still hoping for a little tailwind!  :-D
Mike in Tacoma
Bike #833
55chevr
panic
#4
Let:
S: speed (MPH)
D1: primary drive ratio (clutch wheel ÷ motor sprocket, etc.)
D2: secondary drive ratio (rear sprocket ÷ transmission sprocket, etc.)
G: individual transmission ratio (2.50, etc.), direct drive high gear = 1.00
T: tire diameter (inches)
R: engine speed (revolutions per minute)
S = (T × R × .002975) ÷ (D1 × D2 × G)
R = (S × D1 × D2 × G) ÷ (T × .002975)
D1 = (R × T × .002975) ÷ (S × D2 × G)
D2 = (R × T × .002975) ÷ (S × D1 × G)
sofadriver
interesting.......
sta'tee's method - 138mph
55chvr's online calculator - 178mph
panic's method - 144mph
Mike in Tacoma
Bike #833
I'd use the 178 -- it's faster.  Just say it's the Exit Speed if it doesn't match your time slip.
sofadriver
Quote from: Stan Back on December 20, 2014, 09:53:17 AM
my choice, too!  :-D
Mike in Tacoma
Bike #833
Vinsky
Here's one that covers just about ever variation you can come up with.
http://www.rbracing-rsr.com/gearspeed.html
Sporty Dan
Have you tried the gearing calculator that Sumner put together? It allows you change sprockets to compare in addition to transmission gears. It's down 2 threads here.
panic
55chevr's page is correct - if you input your tire size and drive ratios correctly. The 178 mph result is a GIGO error.
stay`tee
whats a "GIGO" error,  :?,,
in relation to the formula i posted, (primary x drive x final), "drive" is the ratio of the drivin gear, eg 5th @ 1.130,, "final" is the ratio of front to rear sprocket, eg 18/42 = 2.33,,  :cheers:,,
Garbage in garbage out...  :cheers:
Post the particulars and I'll put it thru our calculator
sofadriver
#13
Quote from: Stainless1 on December 20, 2014, 06:48:52 PM
Thanks, Stainless.
Final drive.....3.4
1st....2.54
2nd....1.89
3rd....1.5
4th....1.25
5th....1.09
6th....0.96
front sprocket - 17. rear is 35.
tire is 23.5" (120/60-17)
13,500 rpm
I'm going to try 55chevr's calculator again, too.
Mike in Tacoma
Bike #833
sofadriver
duhhhhh
i was entering tire diameter where the cosportbike calculator was asking for rim diameter
i'll go stand in the corner now
Mike in Tacoma
Bike #833
