Wanted: 29" 'Salt Tires'
Started by 4-barrel Mike, January 09, 2015, 10:16:33 AM
4-barrel Mike
Pete Richardson, #1931 VGC, asked me to look for 'a pair of 29" ( 29"+5" ) dia salt tires. I currently using 28" and would like to try a bit larger.'
I'll pass any responses on to him.
Thanks.
Dynoroom
Most if not all the larger diameter tires available use a 18" wheel. If this is not a problem both Mickey Thompson & Dunlop make a tire in that size range that has been run at speeds of 250+.
If the 18" wheel is a problem then the 28" Goodyear is about it.
4-barrel Mike
Thanks, Mike.  That's about what I thought.  I've passed that on.
Mike --
Is he still running the A rear end?
V-8 rear end?
A quick change might be cheaper than the expensive tires and new wheels.  And more adjustable.
Stan
