Lakester discussion AA/BFL
Started by javajoe79, February 23, 2015, 07:07:52 AM
javajoe79
 I have acquired a lakester that is unfinished to build. It has some issues that I want to bring up and I would also love to hear any ideas or feedback anyone might have.
It is about 26' long and made from an auxiliary fuel tank. It was built to fit a BBC with a large BDS blower on top with carbs. Seems to be plenty of room for any trans and rear end combo as well. It currently is only a frame and body.
My main current concerns are with the roll structure which appears to be part DOM and part ERW. I don't like the ERW but it seems as if the rule book does not prohibit it unless I missed that somewhere. Either way I am considering redoing some or all of the roll structure.
Planning a quickchange or 9" but leaning towards the quickie for the higher gearing.
Lenco trans or turbo 400.
Engine may make 1500hp. 500ci + blown BBC on alky. Zoomy headers or full length in the air?
Front beam axle? Who uses what here?
4 link suspension with watts link front and rear is the plan. Maybe pushrods.
Came with formed lexan canopies. Thinking forward hinged.
Thinking 30" mickey's for the rear and something smaller up front.
615-210-1605
#1
thought I was posting in a private message
javajoe79
Thanks Sparky. I will be in touch. When is a good time?
615-210-1605
How about some pics so we can see what you have?
javajoe79
615-210-1605
55chevr
Well you certainly did describe it as "unfinished".   A lot of welding ahead for you.
ooooooo this thing sure could look bitichin when these guys get through  :cheers: another tank  yeah !! see shades of Charles and strange days!!!
javajoe79
Quote from: 55chevr on February 23, 2015, 03:47:58 PM
Yeah man, no joke.....  Lot's of welding to do and probably will redo the roll structure. Too many bad notches there and would rather it be DOM
615-210-1605
javajoe79
Quote from: SPARKY on February 23, 2015, 04:12:40 PM
Yeah I think it looks cool as all get out...
615-210-1605
Jack Gifford
Envious!!!... of all that interior space!!!
M/T Pontiac hemi guru
kiwi belly tank
Yeah that's what I was thinking too, you might need a little more space when you park your 747 in there at night! :-o
You certainly have a pretty good starter with some obvious things that need to be changed. Redoing the cage is a good idea as the structure around it is pretty poorly designed, I would also ditch the F104 tail structure, not very aero. Looking at what is there you appear to have plenty of room but wait until you get the blown BBC/Turbo 400/ QC  in it then it will definitely be filling up! I happen to be one that believes that on a lakester the wheel/tires should be a fair distance from the body just to insure that the air disturbance from the wheel/tires has the least disturbance of the air going around the body. You see lots of lakesters with wheels mounted close to the body and they will have a salt deposit just in front of the tires, which to me just indicates that the air is not flowing well between the body and the wheel/tire. If you are going to run individual headers I would suggest looking at what the Contrivance Engineering people have done on their modified roadster. I have attached a pic. I talked to them regarding this configuration and they said that for the small amount of additional horsepower that they found with equal length headers they had so much increased drag hanging out in the air that the individual pipes with a fairing were a much better choice. I would not make them zoomie style as they really screws up the air flow over the body.
It is going to be fun watching you get this car completed so please keep us updated.
javajoe79
I like the idea on those headers Rex. I wonder if they have issues with getting accurate readings with the O2 sensor so close to the end like that?
615-210-1605
Those Contrivance guys don't have a clue what they're doing -- running that awkward '23 body!
It's just a coincidence that they hold the AA, A, B, C, D, E/Gas Modified Roadster records at Bonneville.
