Belly Tank Build Diary
Started by Mike Brown, April 07, 2015, 11:57:52 AM
desotoman
Quote from: Jack Gifford on October 24, 2022, 09:33:52 PM
I've been around vehicles all my 82 years but never a "side-by-side". :? Educate me...
Morning Jack, Here is what a "side-by-side" vehicle is.
Hope this helps.
https://outdoortroop.com/the-beginners-guide-to-the-side-by-side/
Jack Gifford
Thanks Tom and Slim. I don't get out enough...
M/T Pontiac hemi guru
Jack Gifford
#618
Quote from: Mike Brown on October 25, 2022, 06:49:07 AM... First car across the finish line wins...
... you cannot run faster than 4.0 seconds in 200 feet or you lose...
"Index racing"- another form of "bracket racing". I understand its popularity, but can't get enthused about it. My efforts have only been in "heads up" motorsports- pulling and landspeed. :-)
Too bad we didn't have ET clocks in pulling. On good clay tracks my 1,800 pound minipuller ran 300' in under ten seconds- dragging a 14,000 pound transfer sled!
Mike Brown
The standard firestop caulk that I used to seal small gaps between my intake piping and the firewall has been problematic.  It gets very hard and is not very compliant.  In addition it is water soluble.  I haul the car on an open trailer and if it rains the smallest amount of water starts dissolving the firestop.  The material cracks up and falls out.  I end up cleaning the material out and reapplying every event.  I found this firestop which is made by Great Stuff and is classified by UL for sealing penetrations.  Has anyone had any experience with this firestop?  Would it be approved for sealing small gaps in firewalls?
The stuff I used is made by 3M and comes in a caulking tube. I forget the exact name but it is commonly available. The stuff looks like red RTV but is rated to a very high temperature and is not water soluble.
Jack Gifford
Thanks for the heads-up on 3M. I'm also suffering from brittle/flaking firestop material.
WOODY@DDLLC
Neil is this it? Lowe's has it!
3M? Fire Barrier Sealant CP 25WB
bearingburner
On our lakester we used a fire stop  material that came in a "caulking" tube. Bough at Home Depot.
Quote from: WOODY@DDLLC on January 26, 2023, 06:49:24 AM
That's it- I bought mine from Home Depot.
salt27
Quote from: manta22 on January 25, 2023, 02:37:28 PM
We use this to seal around fire barriers when building hospitals, it is supposed to swell and seal tight when exposed to fire.
Elmo Rodge
Don, I believe that's called intumescent foam.  :cheers:
Wayno
Mike Brown
This is the fire block caulking that I got from Home Depot.  This sealant is gray in color and will crack as it is more like a mortar than what I think of as caulking or sealant.  It is not approved for use as a fire stop on rated construction.  The sealant that Woody references (3M CP 25WB) is rated for fire stop use and is "intumescent foam" as Wayno describes it.  I will try this material and add a post.
Mike Brown
A photo of the area that I am having problems with the fire block.  I will clean this up well and try the 3M CP 25WB.
Quote from: Mike Brown on January 27, 2023, 08:57:22 AM
It should work just fine. Smooth it out with your finger and it will look decent.
