Near solid mounted front axle
Started by Mr. Schimstock, April 15, 2015, 05:15:03 PM
Mr. Schimstock
I've read some of the threads regarding having or not having a front suspension.  For the purpose of this thread I'm talking about an XO lakester.  I see the benefits of the rigidly mounted front axle (no suspension) but would have concerns about the increased loading from a complete lack of compliance and issues with stress concentration at the mounting points.  Has anyone considered mounting a front axle on some high durometer rubber isolators.  My thinking is that this would allow the absorption of some to the loads and vibration but limit movement of the axle to less than something like .25" It would be somewhere between a suspension and a rigid mount, or maybe a very high spring rate short travel suspension. There are different styles of isolators that could be used to change spring rate in different directions (fore-aft vs vertical).  The isolators typically have some natural damping so I think it would bounce much.
Sproing, crack, ouch!
RichFox
You might talk to Jack Costalla about this. Jack has used a similar deal.
I chose solid but 1/4" to 1/2" would not bother me---I think this would make sense
#3
Quote from: Mr. Schimstock on April 15, 2015, 05:15:03 PM
Granted, it was independent, and operated through levers, but the original Mini Coopers used rubber cones with great success for 50 years.
As long as you can keep everything on the horizontal planes in check, all you'd really need would be what you're talking about, but the caution I have is this - Would the inspectors consider it a sprung suspension, which then requires shock absorbers on each wheel?   :?
I think you could get by with it if you were to mount the axle with large diameter isolation bushings.
kiwi belly tank
Thats quite doable & has been done a few times. Thrust II had rubber cone suspension copied from the Mini. The Herbert Steen liner was suspended with a stack of Belleville Washers. SCTA would likely view it as suspended & require shocks. The rule doesn't say how effective they have to be! :roll:
bearingburner
Front ends suspended by rubber biscuits were used by dragsters in the late '50s early '60s. Chassis Research sold One
Dynoroom
We were going to run front suspension originally but ran out of time & room. Not saying it's right but our car has a solid mounted axle. Has run at El Mirage & Bonneville since 2008 with no problems. 175" Wheel base & 3500 lbs. 240+ mph
saltracer1
I remember seeing a modified roadster with a suspension setup like you are talking about back in something like 1998, came back a couple of years later and he had made it solid. All I remember was the car was Toyota powered and blue in color.
Mr. Schimstock
Thanks for the input.  I think I'll give it a shot and build in some "friction shocks" in the locating arms.  If it gives me any concern during any runs it will be easy to change the stiffness or just swap out the rubber for some metal and voila... solid mount.
dw230
A successful car by the name of Speed Demon uses the 'hockey puck' style of front suspension.
Again, nothing new at the salt.
Jack Gifford
Do most of the above comments pertain to lakes running? If so, can anyone say whether suspension (front and/or rear) would be of more/less importance on the pavement of ECTA and/or LTA?
M/T Pontiac hemi guru
Quote from: Mr. Schimstock on April 16, 2015, 05:59:22 PM
CAUTION - if you make a modification of that nature during a meet, run the car back to tech when you're done and make sure they're aware of it.
Mr. Schimstock
Quote from: dw230 on April 16, 2015, 09:13:19 PM
Figured it wasn't a new idea but had to ask.  Do you know if they run dampeners or just the pucks?
Mr. Schimstock
#13
Quote from: Milwaukee Midget on April 16, 2015, 09:45:28 PM
Yep... I'm thinking pretty much any changes would need to be run through Tech or at least give them notification to they can accept/acknowledge it..... which likely means running through tech again.
Mr. Schimstock
Since we're on the subject of front axles, I assume a decent street rod/gasser front axle would hold up OK on the salt.  Most appear to be 2" OD 1/4 wall DOM.  Thought's/concerns on this using one?
