WANTED: 30 gallon drum/barrel
Started by NathanStewart, May 08, 2015, 09:54:17 AM
NathanStewart
Just like the title says.  I have one but need a second.  Anyone have one they want to get rid of?  Hopefully in SoCal.
Thanks!
El Mirage 200 MPH Club Member
dw230
I have a 60 gal wine barrel, cut it in half and its yours.
Sounds like someone's building mufflers.  :-D :roll: :evil:
I hope they work out for you Nathan. Its likely the cheapest way and you can always upgrade if you need more.
NathanStewart
The barrel I already have (or will be getting soon) is a VP fuel drum.  I'm not picky.  VP, ERC, lemon meringque... doesn't matter what was in it really.  Just needs to be empty.   :-D
jdincau
Nathan,
     I have an ERC drum it measures 28" high by 14" in diameter, will bring it to El Mirage if it will work for you.
Jim
jdincau
Quote from: jdincau on May 08, 2015, 03:49:46 PM
Nathan,
Jim
Looked it up on line it's only a 15 gallon.
Elmo Rodge
I come up with 18.6592 gallons with those dimensions.  :-D Wayno
Quote from: dw230 on May 08, 2015, 10:02:18 AM
Can you deliver that to the TnT or SpeedWeek  :-D  :cheers:
Wayno, I guess that makes 15 gallons of ERC fuel a bargin... they arrive full.... or there is is a flaw in the measurements or the math  :-o
jdincau
Quote from: Stainless1 on May 08, 2015, 05:44:51 PM
All measurements within an inch, mas o menos
Nate  I may have a  VP  you can have a matched pair !
NathanStewart
Perfect. I'll taken them both. Will we be seeing you at Elmo next weekend Sparky?
RidgeRunner
Nathan
     Do take all precautions possible when working on or around them.  The fuel may be gone but vapors WILL remain, bad things can happen fast, I've seen and heard the results.
Nate if it goes I will bring them both
