200 mph LSR Pontiac Firebird $15,000
Started by fastact, May 10, 2015, 02:39:01 PM
fastact
Up for sale is the Geezer Express 1. It currently holds
records at Maxton, Loring and Ohio and has been over
200 mph at all 3 tracks.
Specs-
-Car and Safety Equipment-
1987 Pontiac Firebird
Full 10 pt. roll cage
Ultrashield full containment seat
10# Fire Bottle fire system
Stroud custom LSR parachute
RJS 5 point camlock harness
Tach, water temp, boost, oil pressure gauges
Quick release steering wheel
Complete MSD ignition system
-Engine and Fuel System-
383 cu. in. small block chevy - "B" engine
Eagle forged crank and rods / SRP 8.5:1 forged pistons
Dart Pro 1 215cc aluminum heads
B&M 420 Super charger
2 - 750cfm Holley HP carbs tuned on E85 fuel
Complete Aeromotive fuel system
A1000 pump and regulator
2 - 5 Gallon fuel cells
671hp/642tq @ 8psi on chassis dyno in 2014
-Transmission and Differential-
Pro built 700R4 Auto Transsmisson
Precision Industries triple disc lock up converter
2600 stall
B&M ratchet shifter
GM 12 bolt rear with 35 spline axles, 3.08 gear
C5 corvette front disc brakes
11" rear drum brakes
Weld drag star wheels
Front: 15 x 3.5 with 26" Good Year front runners
Rear: 15 x 12 with 315/60/15 M/T Drag Radials
Car was last raced at Wilmington Ohio in Sept. 2014
and set the A/BFALT record at 203.989 mph.
Car is TURN KEY and READY TO RACE!!
Car is located in Pierson, Michigan. Additional pics available upon request.
Contact Info:
Brian Acton
616-893-2216 (call or text)
nscaracer@gmail.com
