Another engine swap ? , 8.1 chevy
Started by 1leg, May 20, 2015, 07:42:48 PM
1leg
Would a 8.1 liter chevy big block be considered a engine swap in a car or truck that original came with a 396-454 big block?
My understanding is that the heads will not interchange without modification. Also most of the exterior(front cover, oil pan) parts will not interchange. Same bore spacing, Cranks I believe will interchange.
From Wikipedia
The Vortec 8100 L18 was a V8 truck engine. It was a redesigned Chevrolet Big-Block engine and was introduced with the 2001 full-size pickup trucks. It had an all-iron engine (block and heads) with two valves per cylinder. It retained the same bore diameter as the old 7.4 L Big-Blocks, but the stroke was upped by 9.4 mm (0.37 in) to reach 8.1L (496cuin), for a total of 107.95 mm (4.25 in) bore and 111 mm (4.37 in) stroke. Power output ranged from 340 hp (254 kW) to 550 hp (410 kW),[citation needed] and torque from 455 lb·ft (617 N·m) to 690 lb·ft (936 N·m).
Other important differences between the Vortec 8100 and older Big Blocks include a changed firing order (1-8-7-2-6-5-4-3), a new 18-bolt head bolt pattern, longer connecting rods, different symmetrical intake ports, different oil pan rails and the use of metric threads throughout the engine. The fuel-injection system for the Vortec 8100 is nearly identical to that used on Gen III engines, right down to the fuel and spark tables in the ECU.
Jerry
SDRC Member since 2013
Alternate driver 832 roadster
I sure believe so! heads and intake manifold gaskets are not interchanable
