steamliner windshield
Started by bob, June 04, 2015, 09:02:55 AM
bob
 :?question about windshields ? for a liner canopy windshield what type and thickness (plastic) is the way to go. the windows are set into the canopy.   thanks       bob
if its flat a bunch --- if its curved or compound curved not so much  :roll:   we are using .092 Lexan on a curve that is not very vertical  but you may be shooting for a higher number than we are
dw230
Contact Ron Main, speeddemon.com.
Ron has the latest info on windshield materials. These notes extend beyond the normal Lexan and poly materials.
What sort of speeds is the liner designed to go and what is the opening shape you're trying to cover? Photos or sketches would really help.
robfrey
We are using .25" thick lex an on the 496 liner. I designed the car to use a "flat wrap" windshield. This means we lay a piece of paper over the entire windshield and it will not have any gaps or wrinkles. We then made a casting of our windshield area (female) and found a local company that did vacuum forming. It was not vacuum formed but the vendor put it in his big oven to soften the lexan enough for it to take the form of the mold. All was fantastic but I did not no that there was windshield grade lexan that is much flatter than regular consumer grade. It might be good to make a practice piece from the lesser expensive grade along with the good one. If the practice piece turns out alright, you will have a spare..
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
