What chemical in fire suppression systems?
Started by distributorguy, June 15, 2015, 01:55:57 PM
distributorguy
What chemical is everyone using for fire suppression in car?  Halon?  PKP?  Different for interior versus engine bay?   :?
Insanity is doing the same thing over and over and expecting different results.
Racing is the evil modification of insanity.
distributorguy
Sorry I posted this earlier int he wrong area.
I've been using DuPont FE-36, 2 5lb bottles, one for the engine, one for the passenger compartment.
Actually - and gratefully - I HAVEN'T been using it.
You may need more, depending on the class record for the Datsun.  If it's over 200 mph, you'll need additional suppression agent for the driver's compartment.
The rule is 3Q in the book.
jww36
I gave this quite a bit of thought before I built my '34 Ford C Gas Roadster. I opted for Du Pont FE-36 in cockpit, and Firefox foam in engine bay. Reasoning, in case you have an accidental discharge in cockpit, you don't have a mess. But most importantly, with foam in the engine bay, if you put a rod out thru the block, you are going to have a fair amount of oil going on to hot headers. If using Halon in engine bay, it will put out the fire but once discharged, fire may reignite. The foam not only puts out fire but quenches headers too.
Buickguy3
  We learned about Firefox the hard way this year. Take the bottles out of the car and store them in a "non-freezing" environment. The only warning any where is one that says: operating temperature 20 deg.- 140 deg. [I think]. Nowhere on the bottle or instructions does it say a simple: "Caution, Avoid placing the bottles in a freezing environment". We got a $300 lesson. Our Halon Firebottle system was fine. Our fault. Just be aware.
   Doug  :cheers: :cheers: :cheers: [Ya, we still have beer money].
                   [America]
distributorguy
One of our team members just bought a 10 lb halon system.  Fast and hopefully effective, legal in his Chump and WRL cars, and best yet I didn't have to pay for it!
My understanding is that once the system is installed, we can always change chemicals and the nozzles stay the same.
Elmo Rodge
Distributorguy, that's not how I remember it. I had to change nozzles. I don't recall the details at the moment but someone will chime in.  :cheers: Wayno
jdincau
The nozzles are different for gas VS liquid systems, also the liquid systems require the nozzles be on a continuous loop back to the bottle to avoid pressure drop at the farthest one.
Jack Gifford
Quote from: jww36 on June 17, 2015, 09:24:47 AM... If using Halon in engine bay, it will put out the fire but once discharged, fire may reignite...
Thanks for the heads-up, hadn't thought about that. I'm a fan of Halon, from my experiences in tractor pulling- but there wasn't any bodywork involved.
M/T Pontiac hemi guru
fordboy628
I too, have had the very negative experience of an engine bay fire re-igniting after the Halon bottle was empty . . . . .
Halon does not cool off HOT parts.     But CO2 does, as do other chemicals.
Just my 2 cents.
distributorguy
I honestly wasn't aware CO2 was an option.  I have the perfect bottle of that attached to my shop fridge, and no one should need it while I'm gone racing, right???
jdincau
CO2 is an option outside the drivers compartment
distributorguy
I guess we can run a dual system then.  Sounds like a feasible option, safety third as Mike Rowe would say?
Thank you all for the input!!!
Slide
I just met with the safecraft people. (They are close by to my house and are very nice) I told him that I have a full interior car, with a surge tank and pumps in the hatch.
He suggested a single 10 lb bottle of their FE36 agent, with one nozzle in the back by the surge tank, one on the dash by the driver and then two nozzles in the engine bay...
All of which run by a pull lever.
What's everyone think?
Car is 2.5l  Subaru Sti hatchback, running a E-85 (or e-90 ignite), and I'm hoping to make 186 mph in the standing half mile and 205 in the standing Mile.
I'm not looking to be classed in anything. This is for self gratification. The car will the. Become my dedicated track day car.
kiwi belly tank
A pull handle can be tough to find if all hell breaks loose, make sure you put them where you can find them, on fire, upside down in a panic with your gloves on is a whole different world.
This is why I prefer push type & I've been on fire twice.
