extended cab vs single cab aero
Started by robert56, September 25, 2015, 07:03:10 AM
robert56
I'm considering building an S-10 based entry for MMP class.  I've read anecdotally that an extended cab truck has "better aero" than a single cab but I haven't seen any Cd numbers to back it up.  Cd figures are hard to come by for trucks in general.   I know that GM/Banks built the Syclone LSR on an extended cab truck but did they do it for better aero properties or just for the longer wheelbase?  If it was just for the longer wheelbase and considering the fact that I'll be running ECTA and not on the salt I'd be better off with the lighter single cab, I would think.  Thoughts?
Rob
Quote from: robert56 on September 25, 2015, 07:03:10 AM
Rob
My personally feeling is running the mile vs. the salt is just a completely different deal.  You are running a vehicle more or less setup for the drag strip that will run further than the 1/4 mile.   Aero is important but weight could be more important (the less of it the better).  I can't imagine a lot of aero difference between the two and I'd just be looking for the pickup with the smallest frontal area regardless of make that you can get a cage in and yourself.
If I was also making it for the salt also then I'd be more concerned about the aero and the ability to add weight forward to help with keeping the center of pressure forward.
you are going to need the ROOM of the extended cab if you really start trying to go fast with all the stuff you will be putting in there and it will be light years easier to get in and out of when you put the cage in there if you are building a LSR vech.--- for resale  best to keep the salt in mind
1leg
Keeping it light weight will make easier to resale as a drag car too, Just my .02
Jerry
SDRC Member since 2013
Alternate driver 832 roadster
salt27
What I remember is that the extended cab was indeed more aero.
I have the magazine with the story about it around here somewhere.
On trucks the longer the better it appears
gkabbt
Here is a PRIME example of an extended cab S-10 at Wilmington this weekend:
It's Bob Merickle's S-10 powered by a Wayne Jessel Dodge engine. This it's first time out.
Also, Javajoe79 here on lr.com ran a 96 GMC Sonoma several years back and got a Bonneville record and red hat!
Do a search.
HTH,
Gregg
dw230
I've got a four door Colorado that could be turned into a LSR contender.
