Changes needed for 1 or 1.5 mile
Started by Ron Gibson, January 13, 2016, 11:45:45 AM
Ron Gibson
How much weight should be run in a roadster at the mile or mile and a half courses?  Right now I'm about 4000# and I know that's too heavy.
Ron
fredvance
Weight is not your friend on shorter courses. The shorter the course the more weight matters. I would remove all the removable ballast. If you are spinning the tire a lot put some back in the back.
kiwi belly tank
At Bville you add weight to speed it up until it starts slowing down to find the right weight. I would try the reverse of that but not set up a 1/4 mile drag race CG.
Ron Gibson
Hi Sid
That sounds like Dolan's, add gear till you slow down, then add horsepower. :-D :-D
Ron
Davidson considers 4000 pounds too light to run 1.3 miles.
Maybe the answer depends on the roadster's horsepower to some degree.
BHR301
A lot of it depends on what course you are talking about, pavement is a lot different then dirt or salt.
