ETCA Motorcycle classes
Started by BVCBR, January 27, 2016, 06:01:31 AM
BVCBR
We are going to attempt to make it to one or 2 of the ECTA Ohio events this year. I have been looking through the current motorcycle records and have a question about classes;
I see the usual Production, Modified & Special Constriction classes, in Modified and Special Construction I see the usual M-Gas, Fuel, Blown, etc. and I understand the Twin vs. four cylinder, but I also see a "T" designation. I have not figured that part out. Could someone give me the decoder ring settings for the "T" as in M/TG-1000/4?
We have ran a couple of times at El Mirage and Bonneville, is there anything we need to be aware of that is a major difference between running an ECTA event vs an SCTA event?
JW
970B 1000cc P-P
976B 1000cc P-P
977B 1000cc M-G/F
WOODY@DDLLC
Page 77, 2015 rule book TG: Overhead Cam Twin
5383 is M/TG-1000/4
BVCBR
Thanks for the info. I'll get a rule book. It looks like there are a lot more options in the ECTA than the SCTA.
JW
970B 1000cc P-P
976B 1000cc P-P
977B 1000cc M-G/F
Jessechop
Quote from: WOODY@DDLLC on January 27, 2016, 07:44:59 AM
5383 is M/TG-1000/4
Are you sure on the ohc  part?  I thought pushrods were allowed with twins?
WOODY@DDLLC
PG: Push Rod Engine: Gasoline
TG: Overhead Cam Twin: Gasoline
Likewise PF & TF for Fuel
PBG & TBG Supercharged Gasoline
Get the rule book and plan your attack(s)!  :cheers:
'Bout time to send in them dues, too!  :cheers:
Jessechop
Quote from: WOODY@DDLLC on January 27, 2016, 03:48:15 PM
Never knew that,  thanks!  Loring allows pushrod in twin thus why I thought ECTA did also
Truckedup
 SCTA rule book classes are pretty much the same as the ECTA and LTA. But I believe at El Mirage there is no modified production class
Nortonist 592
The SCTA doesn't have a modified production class.  You're production or you're modified.  At El Mirage there is no modified class  Only production or A. Where else would a bone stock featherbed frame have to run in A?
Truckedup
Quote from: Nortonist 592 on April 07, 2016, 03:21:52 PM
So the SCTA has changed the rules in the last few years? I have a three year old SCTA rule book and Section 7F list Modified Production and the class rules. So now it "modified" ? Is it the same as the old Modified Production class?
BVCBR
#9
Quote from: Truckedup on April 08, 2016, 04:53:15 AM
The SCTA "Modified" or "M" class has always technically been "Modified Production". The intent was to have a class that a Production bike with some aftermarket parts, like exhaust, which would not be legal for the Production class, could run. It is intended to bridge the gap between Production and Special Construction classes. It is very seldom refered to as "Modified Production" though.
Also true that at El Mirage, you are either Production or Special Construction; no Modified classes.
JW
970B 1000cc P-P
976B 1000cc P-P
977B 1000cc M-G/F
Nortonist 592
Apologies.  Its been so long that I've heard the words "modified production" I forgot about them.  Always just thought "modified".
Truckedup
 No problem ,we both understand what's going on... maybe you more than me   :-D
