New(?) Idea for Alternative Race Sites
Started by Stan Back, March 03, 2016, 03:02:41 PM
Pat Ganahl sent me this 1947 proposal for an alternative to hauling your Hop-Up to Muroc.  Sounds like a good idea.  Hope you can read the pdf -- it's the best I can do.
Maybe a monthly two-day meet on the 405?
Quote from: Stan Back on March 03, 2016, 03:02:41 PM...  Hope you can read the pdf ....
Not sure if this is better or not,
4-barrel Mike
ronnieroadster
   Wow another opportunity missed     :roll:
Elmo Rodge
Stan, perhaps we could use the driveway to the luxurious "Back Estate". I'm sad to report that the runway of "Salina International Airport" is a bit short.  :-P Wayno
johnneilson
There are plenty of places on I5, chased down a few Bimmers in the Miserati before growing up.
oopps, I lied, if you don't grow up by the time you turn 50, you don't have to.
NathanStewart
On a more serious note, what about the space shuttle landing site at white sands?  With the shuttle program shelved, what else are they using that area for?  I'm sure the problems would be the same as were encountered at Edwards post-9/11 but that's a lot of flat open space not so far from where we're already used to going.  Say they let us use it... maybe we just go onto the area from the other side that doesn't mean driving onto the base through "sensitive" areas.  Meh.
El Mirage 200 MPH Club Member
4-barrel Mike
Freud's summary of Mike Akatiff's discussion at the Bonneville NW Reunion last month:
QuoteWhite Sands, New Mexico has around 7 miles of gypsum runway that could be used, B U T, as always
there is a but involved. It has had no maintenance for a long time. It's not long enough for
400+ MPH records and who wants to clean the car after running on wet gypsum. It is available.
bearingburner
Unless a knowledge group of people actually go and see the conditions we will always be in a guessing mode. Also cleaning gypsum off your car can't be any worse than cleaning salt off your car.
We rode across gypsum playas in desert races.  It is not a surface to be on when wet.  It can be slippery.  In the dry it is nice and hard with a fine dust.  White boogers is my most notable memory.
Jack Gifford
Quick glance at White Sands info:
Longest "runway" was about 3 miles, with 2 mile "runoff" length at each end. The "soft gypsum top layer, 1/2" - 1" thick, required constant grading, repair, and maintenance".
M/T Pontiac hemi guru
Truckedup
Back east we race on abandoned airport runways... Ohio is one mile......Maine is a 1-1/2 mile with enough shutdown for 300 mph.....There must be more out west beside the Mojave mile?
Speed Limit 1000
Truckedup
  Maine  is a Sac Runway......You get to race on  the runways used by  Nuclear armed B-52's  :-D
edinlr
We have an old SAC base in NE Arkansas too.  It is 11602' long and in good condition.  They do some SCTA racing there and the Chamber of Commerce might appreciate our business too.  Keith from ECTA said there are often FAA issues, but it doesn't hurt to keep asking.  It would be a like closer to home for me.
https://en.wikipedia.org/wiki/Arkansas_International_Airport
