Wanted old ford driveline parts
Started by turborick, March 11, 2016, 07:51:27 AM
turborick
Hey guys I need some help finding some old ford parts. I need a
1935 to 1948 6 spline pinion, I don't care the condition of the gear I need to use the shaft.
6 spline drive shaft without a clip groove in the spline area, I just need the shaft I don't need the torque tube or anything else.
And a stock C4 trans output shaft.
All these components will be used on the streamliner transaxle, so if you have or know anybody who has any of these please let me know
Rick Yacoucci
The new Nebulous Theorem 3.5 #788
http://www.bonnevillestreamliner.com
kiwi belly tank
6 spline dirt midget is the same thing including the lower shaft, call Halibrand & check your local trans shops for a C4 shaft, I bet somebody still has one on the shelf.
Elmo Rodge
Rick, I have the 6 spline pinion and should have the C-4 output shaft. I'll look today. How much of the driveshaft do you need? I may have a piece of the splined end. Wayno
Elmo Rodge
Rick, the C-4 output shaft has been cut. Sorry. Wayno
turborick
Quote from: kiwi belly tank on March 11, 2016, 08:01:41 AM
the trans guys think there worth to much money for this guy. im looking for cheeeeeep
Rick Yacoucci
turborick
Quote from: Elmo Rodge on March 11, 2016, 08:10:36 AM
Wayno I need at least 2 inches past the splines
I need to cut the C-4 output shaft also, so where is it cut? picture?
Rick Yacoucci
jdincau
#6
Rick,
    I have a torque tube type lower input shaft from a Hallibrand V-8 quick change. Six splines on both ends. Will attach a picture when the camera finishes charging. Extreemly cheep.
Jim
Elmo Rodge
Rick, I sent you an email with picture. Wayno
kiwi belly tank
Quote from: turborick on March 11, 2016, 08:47:11 AM
Cheeeep is my flavor too, Ebay is my streamliner supply house.
Wayno! is there anything you don't have down there? :roll:
Elmo Rodge
Of course, Sid. Sanity and money.  :roll:  :cheers: Wayno
