1982/1992 Camaro/Firebird Front & Rear Suspension
Started by Skip Pipes, June 16, 2016, 07:40:50 PM
Skip Pipes
In relation to 1982/1992 F-Body Camaro/Firebird to build for Gas Coupe and Alt.
What's in common use for front & rear suspensions? Are there any must-have suspension strategies/components for this vehicle? Direct me to any helpful pics?
For me, I'm enamored with Jack Rogers #757 Camaro... Can anyone revel the type of rear suspension it's equipped with? Also, does it have a QC/12 Bolt/9 Inch Ford rear axle?
Skip Pipes
Skip's Garage
Steve Strupp, Jack's driver/builder/whipping boy, is active on FaceBook.  I don't have an email addy for him, but have a FB person help you if you don't fiddle with that site.
gkabbt
If the 757 is here at Wilmington this weekend, I'll get pics and post.
Gregg
Dynoroom
Skip, you need to be a little careful here. The rule book allows for full tube chassis in Altered but not so in Gas Coupe. I would build to GC specs.
The 12 bolt rear has less hp loss than the other 2 mentioned. Some folks here would recommend a 10 bolt even. This depends on how fast you want to go & how much power you're going to use to get there IMO.
The Kugel/LeFevers Firebird ran a 12 bolt.
Skip Pipes
SSS - thanks for the FB nod.
Greg- appreciate any pics
Mike - thank you so much for the pics, they tell a big story. I agree on the rear axle, still run a 10 bolt in the roadster, seems to handle what I've thrown at it.
Skip Pipes
Skip's Garage
gkabbt
Skip,
Here are some pics I got of the 757 Camaro this morning just after they unloaded it:
As you can see in the last pic, it does have a QC.
Hope this helps,
Gregg
Skip Pipes
Hi Greg,
Thank you for the pics. They were at Elmo last weekend. Pretty good haul to get to you.
Skip Pipes
Skip's Garage
ATS, Inc
You might contact Dave Sarno, I seem to remember that he built the 757 originally, got in the 2 Club back in 2000 in it.
http://schracingheads.net
When I talked to him at SpeedWeek in 2008 I think he was running half a SBC!
The 757 car is the old Doll-Fox-Christopherson Camaro.  I don't remember if the car's provenance includes Dave Sarno, although he did campaign the 348 car in B/GC.
gkabbt
I wanted to get more pics and get info on the suspension but they left yesterday.
They came, they ran (IIRC) 202+, they left.....Plain and simple!  :-D
Gregg
Captthundarr
Here are some pics from our '91 camaro that Amy has had up to 180.57 in the Ohio mile, She says it rides/drives like a dream. UMI adjustable torque arm and cross member, Trailing arms. Drop spindles and adjustable struts up front. It currently sits with about 1.75" clearance to the oil pan.
Captthundarr
Some more..
Captthundarr
Skip Pipes
Hi Frank,
Thanks for the pics. Are you using an up-rated rear spring/shock? On the front struts, QA1 adjustable? On the spindles are they 1LE's or aftermarket? Back in the 80's I had one of the first Pontiac 1LE's.
Skip Pipes
Skip's Garage
