Corvette C5 diff mated directly to a Liberty 5-speed trans
Started by ggl205, August 01, 2016, 12:58:09 PM
ggl205
I saw subject trans/diff done somewhere and I thought it was on one of the LSR threads. Does anybody know of this trans/diff merger and if so, where can I find it? It will be greatly appreciated.
BTW, if not a Liberty trans then Richmond, Doug Nash or G-Force will be fine.
John Burk
Two transaxle combinations were mentioned a few months ago . Pfitzner makes or is hoping to find customers for their transmissions that bolt on the back of a Winters QC . The other was Griffin who years ago made and might reproduce differential units that bolt to Doug Nash / G Force transmissions .
ggl205
Quote from: John Burk on August 01, 2016, 06:49:36 PM
John, thank you for the Pfitzner and Griffin transmission recommendations. Big bucks to be sure. I am trying for a more cost effective solution as an alternative to these $10,00-$15,000 Transaxles. I will have a 700 hp, 2.0 Liter four cylinder available to me in a couple of years and will need to find an affordable transaxle to put behind it.
floydjer
kiwi belly tank
Here's my backyard way to get there.
I believe your Doug Nash will have a GM 32 spline out put correct?
Park a male Greek Coupler on the end of it, about $90 worth.
Use the earlier Vette 7.5-10 bolt diff that will give you lots of tall ratio options in a 2 series from 3.08 up to 2.136 (aka 2.14)
Use a Torsen or Eaton 2 series carrier that does not have spider gears or cross shaft.
Mike at B&J can make you a female Greek Coupler for the 10 bolt pinion, about $120.
Mount the whole mess in your chassis, no need to adapt them together.
Without spending piles of money I think the tallest ratio you can get for a QC is 4.11, now you have to overdrive the crap out of it either with the spur gears or the trans to get the final drive ratio you're looking for & that is going to cost you HP.
The 4L80-E trans is something you might consider too. It's plenty strong enough in stock form for everything you will shove through it, has a .75 overdrive, 32 spline output, a lock-up converter & is easy to make full manual with no ECM. We hung a used $150 Craigslist cheapy on a twin turbo Duramax in a street rod five years ago that's done Drag Week & has over 20k hard miles on it since. I call that value! A 2WD Turbo 400 short tail housing will bolt up to a 4WD 4L80-E trans to make it a short 2WD.
ggl205
Quote from: kiwi belly tank on August 03, 2016, 12:12:38 PM
Sid, you are talking my language! I like keeping the rear axle as close to the engine as I can, hence, transaxle. But when you leave 300 ft. Lbs. of torque, most transaxles begin to get real pricy. I will look into your options. They make sense. Thank you.
