Nitromethane
Started by DKrause615, August 06, 2016, 08:46:40 AM
DKrause615
I have 20 gallons of 100% Nitromethane  sell to someone at Speedweek.  It is in new 5 gallon containers that I purchased from a major NHRA top fuel team.  My wife says get that stuff out of the garage.  Can I bring it along to Speedweek or am I going to get yelled at by somebody?  :?
rouse
I my bike don't behave out there I may want to get some from you :-D
Rouse
Johnnie Rouse
mergatroyd
I am possibly interested depending on how things go out there. Metal containers (I ask dumb questions all the time)?
I have no idea what I'm doing... but it seems to be working!
DKrause615
The fuel is in new plastic 5 gallon jugs as sold by Summit, Jegs, Speedway etc.  Two are blue and two a red in color.  I also have 20 gallons of pre mixed nitromethane with methonal alcohol. They are 20%, 25%, 30% and 35%.  I wasn't planning on bringing those out to Bonneville but I could if someone was interested. Your vehicle must be running alcohol to use this stuff.  I would also recommend compression ratio be under 12:1.  I have all the  hydrometer test equipment to verify the specific gravity.
Depending on what percent you want to run I can provide the approximate increase in torque and how much you must richen your system for any % mixture at any given density altitude.  Despite what some people say,  you don't  need to change jets until 30% plus.  It's not rocket science , but close.
I had duel fuel systems on my car and would switch to 30% nitro at the three or four mile mark.  It would pick up about four miles per hour.  This years motor is a ultra high compression experiment, so I just as soon move this "rocket fuel".
I am concerned about several things.   #1 I had to apply for a federal permit to even buy 50 gallons of nitro, so it probably should be used at the event.  #2 Since I only have a very limited quantity, I am hoping that SCTA the fuel truck guys don't take offense. #3 The persons buying this realize the proper storage and handling.  #4 Nitro can add torque to any engine when used properly, but your doing so at your own risk.
stay`tee
Quote from: DKrause615 on August 07, 2016, 02:56:04 AM
  :-o, WHAT!!!
DKrause615
Realize that may have been a little over your head.  Have a safe trip, see you on the salt! :-D
stay`tee
#6
 I would suggest that you to not make a jet change, your initial methanol a/f is way over your head  :-D
mergatroyd
Well, my interest is precluded by my ECU taking a shit on my test bed. I'd like to run maybe %20 or so, but at this point I can't even tell if I will be running on M100.
