Car 718, blown 2007 Chevy HHR for sale
Started by Gary Perkinson, September 09, 2016, 08:54:07 PM
Gary Perkinson
Well, folks, it's been a ton of fun, and I've met a lot of great people, but it's time to make room for some other (more stationary) car projects. So I've decided to put the little green HHR up for sale.
The car holds the Wilmington G/BGALT (153 mph), G/BFALT (149 mph), and Loring G/BGALT (148 mph) records, and was actually included in the 2015 Speedweek program--but for obvious and unfortunate reasons, wasn't able to run the salt that year. ZZP in Grand Rapids, Mich., built the engine and did the tuning, and Joe Timney at Delaware Chassis Works did the cage and most of the other safety stuff. The car is teched to 175 at both Wilmington and Loring, and despite the two crappy passes I made in Wilmington in April, the car is now tuned for C85, made 479 hp/452 ft.lbs. at 29 pounds of boost on the dyno, and should easily run in the 160s.
Here's the lowdown:
2.0 liter GM Ecotec Gen 3 LDK engine (inline 4, mounted transversely)
Front-wheel drive, F40 6-speed manual transmission (from a 2007 Saab 9-3)
BorgWarner AirWerks S200SX-E 52/57mm 300-650 HP Complete Turbo
479 HP (WC) and 452 ft.-lbs. torque (WC) at 28.9 lbs. of boost (dyno sheet available)
TiAL 38mm wastegate
ZZP LNF front-mount air-to-air intercooler
Fidanza forged aluminum flywheel
South Bend Stage 4 clutch assembly
Stock LE5 head
Forged Ecotec LNF crank
Forged Ecotec 4340 connecting rods
Forged and coated JE 2618 LSJ/LE5 pistons
ZZP billet engine mounts
82# valve springs/titanium retainers
Mototron 80 lb. injectors
AEM E85 High-flow in-tank fuel pump
Fuelab adjustable fuel regulator
Stainless steel ZZP HHR catback exhaust (cat and muffler deleted)
3-inch stainless steel Cobalt/Ion downpipe and exit downpipe
Delaware Chassis Works full cage, 1.75-inch mild-steel tubing
Ultra-Shield full-containment seat
Stroud five-point quick-release racing belts
Stroud window net
Firefox fire-suppression system (10 lbs. to engine, 10 lbs. to driver)
Deist SFI 4.1 transmission blanket
Delaware Chassis Works custom parachute mount
Delaware Chassis Works custom push bar
Stroud land-speed ribbon-style parachute
S&W aluminum dash
All windows Lexan except stock windshield
Aluminum roof rails
Aluminum windshield and rear-window retaining clips
GM 34mm LSJ upgraded axles
R1 Concepts drilled and slotted front rotors/stock rear drums
Timken hubs, drilled by Mourer Machine for 1/2-inch Moser studs
Six Wheel Vintiques smoothie wheels, 16" x 6.5", 5 x 110 bolt circle, 5" backspace
Eight 225/50ZR-16 Toyo Proxes RA1 racing tires
Odyssey Extreme PC-1200 dry-cell battery
Flaming River remote battery cut-off
ZZP inertial shut-off switch
240-mph GPS speedometer, stock tach
AEM fuel and AFR gauges
Stroud SFI 3.2A/20 fire pants
Stroud SFI 3.2A/20 fire jacket
Stroud SFI 3.2A/20 fire boots
Stroud SFI 3.2A/15 gloves
Stroud head sock
Stroud SFI-approved arm restraints
Bell full-face helmet, approved until 2022
Adjustable Hans device
Car is dipped Hunter Green (originally gold)
This car would be great for someone who's interested in trying out land-speed racing but doesn't want to break the bank, or someone who might have Bonneville on their bucket list. The car is ridiculously easy for one person to run--I can get it on and off the trailer, by myself, in five to ten minutes, and with a little practice, I was able to get myself belted in, up to the starting line, and the down the track pretty much by myself.
Here's a video of one of my Loring runs: https://youtu.be/K-_EC9Ho6dA
I've attached some photos (many more are available), and I'm willing to deliver the car within roughly a 750-mile radius of NYC.
$8,000 obo takes everything (except the trailer, although I'm willing to discuss). You can tow the car to Wilmington at the end of the month, turn the key and go 150 mph. It's a safe car that's easy to drive, with a lot of quality parts (and fun) for not a whole lot of money.
I might be interested in trading for a decent later C3 Corvette, but other than that, cash only. And thank you, but I don't need to sell, and I don't need help selling.
PM me here if interested, or e-mail me at gfp61@mindspring.com.
Thanks!
Gary Perkinson
LTA     G/BGALT Record (1 mile)     143.313
LTA     G/BGALT Record (1.5 mile)  148.321
ECTA   G/BGALT Record (former)    153.009
NathanStewart
El Mirage 200 MPH Club Member
Gary Perkinson
Thanks, Nathan and Pete...I think it's a pretty good deal, too, although I also understand that it's an oddball that probably doesn't appeal to a lot of people. I guess Mr. Market will do the talking!  :-D  In the meantime, however, I just picked up the perfect inexpensive mule--a 5-speed HHR panel van into which the powertrain, fuel system and anything else that can be swapped out of the race car will go. The land-speed HHR will live on as a street cruiser, so anyone who wants the race car should probably act quickly...  :-o
SteveM
SCREAMING HOT DEAL!
As I read through the ad, I was expecting to see a number on the high side of $20K.
Oh my, now I'm thinking about a home equity loan.....
