SOLD - Busa & ZX12 motor building tools for sale (as a lot only)
Started by entropy, November 01, 2016, 09:49:58 AM
entropy
Hi Guys,
the stuff listed below cost me $6,666 new.
I'll sell all of it as a lot for $1500 delivered
With that stuff i truly learned to BUILD my MC motors, not just assemble parts.
I won't talk about the number of motors i blew up while learning :D
guntekd@gmail.com      new cost
1   Snap-on 1/4" drive tq wrench 40-200 in-lbs, mfg jan/05   #QD1200   285
2   Snap-on 3/8" drive tq wrench 5-75 ft-lbs, mfg jun/05   #QD27x   305
3   Snap-on 3/8" drive tq wrench 5-75 ft-lbs, mfg nov/10 # QD27   305
4   Husky  1/2" drive tq wrench 25-250 ft-lbs   #39104l   197
5   Time-sert M8 x 1.25 metric thread repair kit  #1812   72
6   BIG-SERT Oversized Metric Kit M10 X 1.25 Part # 5012   89
7   Mitutoyo #155-903 5/16-6" 6-piece telescoping gage set   170
8   Compression test kit w/ quick release hose & 10mm plug adapter   80
9   Snap-on leak down kit EEPV309A00   299
10   bag full of feeler gauges   20
11   Mitutoyo 545-134S Dial Bore Gauge, 1.475-2.075" Range, 0.0005" Graduation, +/-0.0001" Accuracy   $300
12   RINGMASTER Master Setting Rings 1.5000"   156
13   Fowler Full Warranty 52-562-001-0 Horizontal White Dial X-Test Indicator, 0.0005" Graduation Interval, 0.060" Maximum Measuring Range, 1.5" Diameter   118
14   Mitutoyo 293-347 Coolant Proof LCD Micrometer, Ratchet Thimble, 3-4"/76.2-101.6mm Range, 0.001mm/0.00005" Graduation, +/-0.0001" Accuracy   275
15   Dyers Top Rods rod bolt digital stretch gauge   200
16   Fowler & Nsk 72-229-104 0-4" Micrometer Set - 4 Piece   156
17   Grizzly G5727 Micrometer Stand   22
18   Mitutoyo 2416S-10 Dial Indicator, #4-48 UNF Thread, 3/8" Stem Dia., Lug Back, White Dial, 0-100 Reading, 57mm Dial Dia., 0-1" Range, 0.001" Graduations, +/-0.002" Accuracy   107
19   NOGA Dial Gage Holder Magnetic Base - Model: MG61003 AUTO POWER: On/off mag.base HOLDING POWER: 176 Ibs Heavy Duty   92
20   Dial indicator 0-1" .00" (no name, works great)   40
21   magnetic dial indicator base ("made in China, works great)   30
22   Mitutoyo 293-340-30 Digital Micrometer, Inch/Metric, Ratchet Thimble, 0-1" (0-25mm) Range, 0.00005" (0.001mm) Resolution, +/-0.00005" Accuracy,   125
23   Mitutoyo 293-341-30 Digimatic Outside Micrometer, 1-2 "/25.4-50.8 mm,0.00005"/0.001 mm with Standard Ratchet Stop   190
24   2" - 6" DIAL BORE GAGE SET - MITUTOYO   379
25   Mitutoyo 511-742 Dial Bore Gauge, 1.4-2.5" Range, 0.0005" Graduation, +/-0.0008" Accuracy   "356
26   Fowler Full Warranty Extender Dial Bore Gage Set, 52-646-400, 1.4-6" Measuring Range, 0.0005" Graduation Interval   102
27   Ideal Heated Knives Tire Grooving Iron 250W -KNP125L   92
28   MARSON Poly-Nut Set - Model: 39203 Thread Size: 4mm,5mm,6mm,8mm Package Qty: 84   121
29   Dye Penetrant Crack Finder Kit - 10010   47
30   MAC Tools 22-PC. BUSHING REMOVER AND INSERT KIT   109
31   "MAC Tools 10-PC. RACE BEARING AND SEAL DRIVER SET
"   92
32   MSD Ignition 8992 Timing Light   167
33   Performance Tool W80578 Self-Powered Timing Light   52
34   HOT CAMS INSTALLATION KIT CIK-001 - $129, missing $25 degree wheel   104
35   "Vee Gee Scientific 20114-50 Borosilicate Glass Class A 50 mL Buret
(used to ACCURATELY determine static compression ratio)"   27
36   approx 75 #3, #4, #6 AN hose fittings, this is good stuff, est low ball cost   300
37   approx 100 pushlock hose fittings, , this is good stuff, est low ball cost   200
38   approx 100 NPT fittings, , this is good stuff, est low ball cost   100
39   Recoil 35060 Wire Thread Repair Kit Metric M6-1   40
40   Recoil 37100 Wire Thread Repair Kit Metric M10-1.25   50
41   5403-7 Helicoil Thread Repair Kit M7x1   43
42   JONARD TOOLS Cable Cutter JIC-63050   33
43   TORQUELEADER 016200 QUICKSET 5 SCREWDRIVER, 10-50 in-lbs   135
44   Safety wiring kit  w/ new 1# roll x .032 stainless wire   30
45   Craftsman Professional Retaining Ring Pliers, Internal/External (2 sets)   46
46   SM-28 Skymaster Wind/Weather Meter   189
47   4 pcs Auto-motive Car Truck Stud Remover / Puller Wrench Extractor Removal Tool   45
48   9 various pressure gauges, all should be good   300
49   roll of medium ss shielded hose, various lengths   54
50   roll of small ss shielded hose, various lengths   50
51   roll of small ss shielded & covered air hose, various lengths   50
52   Mityvac MV8000 - Automotive Tune Up and Brake Bleeding Kit   30
53   2 x 12oz bottles unopened Bel-Ray Silicone DOT 5 Brake Fluid   26
54   3 oz greasegun (loaded) w/1 new cartridge   20
      6666
edinlr
Pretty much my dream list for shop tools, sorry I missed it.
