Fuel Injection, mech vs electronic
Started by oj, January 25, 2017, 06:44:56 AM
oj
Seems to me the simpler system is the better.  If we are running at WOT mechanical has an advantage, it throws fuel into the cylinder at a predetermined rate.  The tuner is the one to figure the rate.  Seems simple enough for me, if you burn a piston you know who and what to blame.  It'll take an engineering conferance to figure why theres a hole'd piston in a computer controlled engine.
OJ, been to Bonneville?
One thing you hear is a lot is stumbling... burbling... those usually occur while the motor is trying to get cleared out enough to get to WOT.  Is that a tuning problem?  I don't really know...
It is not that hard to tell what happened if you burn a piston with EFI... it is the same as MFI.... you failed to provide enough fuel compared to air.....
it is all about selection  :cheers:
oj
No, I haven't been to Bonneville and regret running my mouth, it was a morning post while on my 3rd cup of coffee.  I dunno what I'll use, I'm not even ruling out carburetors.  It is as much an intake design consideration as the means of getting gas to the intake valve.  I think those long nozzles that sprint cars use on mechanical injection have the advantage, but I'm not familiar with all the forms of electronic injectors either.
Quote from: oj on January 30, 2017, 06:33:05 AM
  Our FAST EFI shows the air fuel ratio on laptop from start to finish at all rpms and even corrects 20% rich or lean
   Biggest problem is learning the system or knowing someone who does.
   We made 2080 hp at rear wheels with mechanical but was unreliable starting. EFI 2350 hp starts right up.
   This with centrifugal blower harder to set up than roots type.
    Unblown mechanical would be simpler. And their is data recorders and sensors that record air fuel and lots of
   other things. But it cost $
John Burk
Airflow Performance mechanical injection is an alternative to EFI and conventional mechanical fuel injection :
http://airflowperformance.com/index.php/store-2-2/
It's a Bendix mechanical fuel injection normally used on aircraft that they modify to allow external mixture adjustment . Similar to a Rochester MFI . Being intended for aircraft it works fine at all throttle positions . I learned about it from Ken Walkey and chose it because ram air pressure doesn't throw it off and it fit in my limited space . You mount on your own manifold .
John,
I think you have discussed this injection before. Since you have one how about a pic or two?
John Burk
WOODY@DDLLC
Quote from: John Burk on January 30, 2017, 07:58:20 PM
Interesting but Norton flags the web-page as malicious! :-( Farce-book page is OK! :cheers:
