Bonneville Test & Tune
Started by jww36, June 23, 2017, 03:56:55 PM
jww36
Need some help here from the gearing guru's.
I have a C gas roadster that I run a 3.22 final drive ratio at El Mirage. On the long course at Bonneville I run a 3.08 final drive. I plan on running at the USFRA Test & Tune which will run a three mile course.
Any suggestions regarding gearing?
Roadster #114
I'd say your split between the two is about right.  The difference (to me) between the three and the five is about 1 to 2%.  But I must say, you're either turning a lot more RPM or got a bigger tire than we've used.
jww36
Redline is 8500 RPM. After that I start hearing noises!
turborick
we typically gear for 100mph more for Bonneville minimum
Rick Yacoucci
The new Nebulous Theorem 3.5 #788
http://www.bonnevillestreamliner.com
He's got a real slick roadster, but I think he reaches the "wall" long before you do, Rick.
