Looking for a source for rollers and pins to use on the tip of roller rockers
Started by ronnieroadster, August 27, 2017, 05:29:09 PM
ronnieroadster
Hi All
  I'm working on some one off roller rockers for a special project since I'm machining these myself I need to locate a source for some rollers and pins to use on the valve end of these rockers. I need 32 sets.  Would anyone have any ideas or suggestions on where I might be able to locate parts like this for this do it yourself project?
Ronnieroadster
jacksoni
As I recall Jesel provides a rebuilding service for some rockers (as well as lifters). Is possible they may be able to provide what you want if your design matches what they have. Suspect, as with all Jesel stuff, not cheap if they will supply. Worth a call.
Jack Iliff
G/BGS-250.235 1987
G/GC- 193.550 2021
G/GMS-182.144 2019
G/GCC- 194.580 2025
RichFox
Some years ago I assisted Bob Dalton in making some roller rockers. I think I remember he got the parts from Isky.
jdincau
Fred Blanchard at
http://raceenginecomponents.com/index.html
is making roller rockers for his stuff, he may be able to point you to a supplier
Buickguy3
  One more possible. T&D Rocker Arms may be able to help out.
                   [America]
ronnieroadster
INA and Torrington make roller and needle bearings.
I guess I'll ask the unasked questions.
If you're going to the effort of making your own roller rockers, what's stopping you from producing the roller itself?
As to pins, what kind of spring loads are you looking at?
I would call Richard at Isky, tell him what you are doing, ask about red zone rollers and pins.
4-barrel Mike
4 valve heads on an 8 =32
My guess is 4 valve OHV heads for his UHV motor
Jack Gifford
I did exactly what you intend- designed and made follower fingers for my one-off DOHC conversion. Ron Iskenderian was very helpful- supplying not only tip rollers/shafts/clips, but also freely sharing information. I also used their EZ-Roll wheels/shafts (non-needle) at the cam-contact of the followers. Ron provided enough info so I could make my own coining dies for the shaft ends (shaft ends not hardened). Call him (best time is near 5PM Pacific Coast Time) 310-217-9232.
M/T Pontiac hemi guru
jimmy six
I bought the pins, clips and rollers from Isky because of the pin and design 25 years ago. Everything went well until Ed came out of his office hearing what was going on. Almost stopped the deal but ok'd it when heard they were for a GMC 6 and he didn't make anything for it. But only allowed me to buy 15 just in case I was fudging the truth. I still laugh about it today. None have ever failed. JD
ronnieroadster
Jack Gifford
Although Ed still visits the office, Ron and his brother run the company now.
