roadster steering stops
Started by jdincau, September 25, 2017, 11:34:28 AM
jdincau
Hi all,
    I am looking for ideas. In my Street Roadster I have a sprint car style front axle. Currently the tie rod hitting the shocks is the steering travel limiter. A spin at speed week with a tank slapper while traveling backwards resulted in a bent tie rod and dents in the shocks. I cant use the standard early Ford solution with long nuts replacing the ones on the king pin retainers as this axle has a set screw in the end of the axle to retain the king pin. First thing I thought of was a stop on the tie rod hitting the frame, while straight forward it is not very elegant. A site search only found motorcycle solutions.
Jim
RichFox
I welded stops in the form of sections I cut from a steel circle I made, to the king king boss. I put both on the same side. But you could do one on each side if you wanted.
Hi, Jim -
I just pulled up my pictures of your car from last year at Elmo - any possibility of choking it off at the steering box, under the skin?
Keeps any additional pieces out of the wind.
kiwi belly tank
Welding some to the king pin boss is probably the most simple way for you by the sound of it but you might want to add a steering damper while you're in there, might save you getting broken thumb's "next" time.
If you use a rack & pinion, simply place a length of tubing over each end of the rack and add a big washer behind the ball joints.
fordboy628
Quote from: manta22 on September 25, 2017, 06:26:34 PM
Or just "shaft collars" bolted on to the rack in an appropriate place.
Jim, what type of rack are you using... I ask because we found center load racks to work well in these situations.  Since the tie rods connect in the center of the rack, not the ends, you can resize the rack to fit space and keep tie rods long enough.  So if you want to limit travel, you just cut the ends of the rack off and install stop blocks inside the housing... or if you need the rack to be smaller, you cut the housing off as well and limit steering as much as you want.  I would take a picture of the rack I shortened for the liner, but it is in Australia being mounted in the SoS.
I trust your rack is mounted on your axle to prevent any bump steer.
jdincau
Hi all,
     The setup in question is a custom made straight axle like a sprint car. The steering box is standard right angle modified Japanese mini pickup unit. The rotating components are all out in the breeze already Chris so I cant hide anything from the air. I like Rich's idea seconded by Sid but the axle is chromed and one of the few shiny parts on the thing so I am loathe to weld on it. I am toying with the idea of something that clamps around the axle inboard of the kingpin boss with lugs that bear on the back of the spindle accomplish ing the same thing as Rich's idea. More later.
Jim
jww36
Does your steering box have an arm with rod end on it?
RichFox
Can you attach a small wedge or something to your backing plate/spindle that will work?
jdincau
#10
Good idea Rich, I will look at that. Meanwhile here are some pictures answering the other questions.
jww36
Tried to take a picture of mine but file is too large. Here is what I did on my roadster. If the rod end in your steering arm has a .500" bolt, make a .500" ID x .620" OD x .25" long steel bushing. Obviously you will need a longer bolt. Take a piece of 1.00" wide x .125" thick steel strap and machine a .625" slot in the strap as long as the travel of the steering arm. Weld a threaded bung (.312" or .375") on frame to secure the other end of the strap. The bolt holding that strap will need to be slightly loose allowing strap to pivot so it will need to be safety wired. I even put thrust washers on mine. The .620" OD bushing on the steering arm bolt slides in the slot until it reaches each end of slot.
Does it work? I hate to say it, but I spun my roadster at 220 MPH on the salt. The hard left hand turn my car took was so violent it literally took the steering wheel out of my hands. After several revolutions and the steering going lock to lock I was finally brave enough to grab the wheel and hold on. Nothing in the front end was damaged at all. I'm sure had I had simple spindle stops, the front end would have been severely damaged.
jdincau
jww,
     A elegant solution, I am going to sketch it and save it for future use. Unfortunately the bolt in question is 3" above the frame rail and the radius rod mount is in the way. It's still neat though.
Jim
jdincau
#13
Rich,
    What do you think of me drilling and tapping the back side of the spindle and using bolt heads as stops against the king pin boss?
Edit,
     Now that I look at it perhaps aluminum wedges as you described would be better, I might be able to counter bore the bolts into the wedge so just the aluminum would bear against the axle.
RichFox
#14
In think either will be fine. Aluminum might be better on the shiny stuff. You might put the bolt head on the wheel side and thread the wedg. It really isn't going to be stressed if it's located right.
