Scoops, injector, etc. outside of roll cage?
Started by Jack Gifford, November 12, 2017, 08:40:31 PM
Jack Gifford
The prior owner of my lakester used a port-injector system, but my engine will have a blower/injector/scoop that will extend somewhat above the existing roll cage and body. In another thread I stated that I intend to assure that the little gasoline primer tank is inside the cage. But what about the injector with its alky system- nozzles, hoses, barrel valve, etc.? Have I missed a rulebook section that clarifies these requirements?
M/T Pontiac hemi guru
Nope... when your motor quits the pump will stop pumping...
Jack Gifford
#2
If damage were at or before the barrel valve a lot of alcohol could get pumped (or drained) before the pump quits turning. :-o
I tend toward modifying the cage to minimize such potential.
n49racer
I run a mech. Pump on my EFI'd RMR with a electric primer pump. Now I need to have both an electrical shut off and a mechanical shut off. I didn't think I needed a roll over switch on the primer pump. The tech guys didn't quite know how to respond but I'll put the switch in to save the trouble.
Ted
B/STR  209.97 best
B/RMR  248.45 Record Holder 2012
B/FRMR  248.85 Record Holder 2012
2 club member 2012
kiwi belly tank
Quote from: n49racer on December 21, 2017, 06:00:24 PM
Ted
If your primer pump is on a momentary switch, that should satisfy the rule.
n49racer
B/STR  209.97 best
2 club member 2012
