Rulebook
Started by Jack Gifford, December 14, 2017, 09:15:38 PM
Jack Gifford
Does ECTA publish a rulebook, or are rules all based on SCTA?
M/T Pontiac hemi guru
RidgeRunner
Jack,
     They have in the past.  Some what of a reorganization is currently underway with the latest changes in venue and leadership.  Indications are that more specific info on the coming season will be coming our way sometime after Jan 1st.
     ECTA and LTA rules and classes are very similar to, but not exactly the same as, SCTA.  There are many subtle differences between all 3, it helps to have all 3 in hand for prep and participating.
Jack Gifford
Thanks Ed. Anybody no longer using an out-dated ECTA rulebook they want to donate (or sell?) to me? Same question for LTA?
olepaw
Hi I have a couple old ECTA rule books for free. contact me at my e-mail. Jim
D/CGC record Ohio mile
G/GC   record Ohio mile
H/GC   record Ohio mile
E/FSS  record Ohio mile C/GC TRYING
LittleLiner
The 2016 version of the LTA rule book is online - http://docs.wixstatic.com/ugd/3bd111_e855c8b54e6f471fa9bbc5a5ebcdca37.pdf
What class or classes are you planning to run?   Maybe someone can offer some help on a particular class - rule wise - for ECTA and/or LTA.
Jack Gifford
#5
Thanks for the replies.
Jim- sent you an email.
Littleliner- I've started reading the online LTA rules. But I'll still be looking for a printed copy, which is easier for me to compare with the SCTA book.
I'll run F/BFL, if anyone wants to point out differences from SCTA rules (in ECTA and LTA) for that class.
Ctrl P will get you print.... if you have a printer  :cheers:
Jack Gifford
Both ECTA and LTA rulebooks on their way to me.
Thanks guys!!!
LSR Mike
IMHO if you build and equip to the SCTA Book, you will be fine at any venue. with that said, you will be way overbuilt for some.
Mike M.
BNI/ECTA
Jack Gifford
Yeah, I realize they are all based on the SCTA rules. While I've got time (very wintry here!) I want to look for any rules differences- hoping to avoid surprises.
Kool Performance
You will need 4 wheel brakes.
Jack Gifford
Thanks for pointing out the 4-wheel brakes. I'll have to forget about deleting the front brakes in favor of inboard wheel discs.
ronnieroadster
The four wheel brake rule eliminates a number of vehicles that run at Bonneville. My car as an example uses top fuel front tires theres no way a brake on those tires will accomplish anything its actually going to make it dangerous. Theres lots of LSR roadster that also have only rear brakes. For my car Dual chutes should be an option. Would like to run at the new location but looks like thats not going to be possible with the way the rule is written oh well.     :-(
Quote from: ronnieroadster on February 08, 2018, 12:46:09 PM
I don't think anybody says they have to be great brakes.
I modified the spindles on the front of the Midget, but I'm thinking that if I want to run in Arkansas, I might be able to adapt rotors and calipers  off of a small motorcycle.  Or maybe even drums off of an old Mini Cooper.
ronnieroadster
MM that gives me an idea maybe I can adapt a set of brakes off a 10 speed bike danger averted.   :cheers:
