sway bar pros and cons
Started by noturbo999, February 06, 2018, 10:49:13 AM
noturbo999
Hey folks,
Does anyone have knowledge they can share about sway bars? I have a Mazda RX7 I'm building with a Chevy LS swap (C/GC). The oil pan interferes with the front sway bar, so I'm contemplating removing it completely. I'll hopefully be working my way up to 200mph, so I certainly want stable handling.
Thanks
By "sway bar" I am assuming that you are talking about the stock anti roll bar. Anti roll bars actually only work when turning, going straight they are just along for the ride. Although I am sure that you will be loosing some roll stiffness you can probably get most of it back by increasing the spring rate of the front springs, which you will probably do to compensate for the extra weight of the LS over the Mazda rotary, so my vote is to just not run the stock anti roll bar. What year is your RX7? All of them seem to work pretty good on the salt.
kiwi belly tank
I'm not familiar with the RX7 front end but I assume it's McPherson strut type.
The change to an LS engine plus all the added structure & safety equipment you need will significantly raise the CG then you add into that the extra torque from the LS, you should expect to see some body roll under power. With variation in traction &-or you coming off the power, that will change & that will likely create a yaw situation. On the salt that can mean you are looking at the start line or getting 360 views & a trip to re-inspection before changing your shorts. :-o
I know of some door slammers that have huge sway bars from box trucks & motorhomes under both ends.
Go to the junkyard with you tape measure & find something you can adapt.
I remember an RX-7 that cut in line in front of us at SW in the 90s.  It made quite a journey on its lid.  It was pretty stable in that configuration.
It is always good to know the most stable configuration for your vehicle...  :roll:  :cheers:
Ron Gibson
Do you mean sideways isn't it ?
Ron
No.  It was on its top.  They dragged it off that way.  We then qualified.  Didn't hurt the track much on that smooth top.
4-barrel Mike
Cut in front of you in line?  Ended up on his top?  Ice pick in the left rear?  8-)
Naaa.  This was in the stupid year of pre-staging. They told us to move up.  I hadn't towed the race car before, so I went carefully and leisurely up to the back of No. 1.  Apparently they wanted to be 9 back instead of 10 back and I wasn't going fast enough, so they went around me.  Big hat with some imported cattle.  Karma.
jdincau
Was that the white one the starting line crew had a hard time communicating to the non-English speaking crew that the car had spun and crashed?
kiwi belly tank
jacksoni
Notice that the driver was able to extricate himself from the upside down car, see the flames, and reach back into the car and presumably hit the fire bottles before the crash crew arrived. Think how much harder if the new head restraint rules for cages and swing out bars etc made that much harder. Maybe we should have bail out tests with the car upside down...... :evil: :evil:
Jack Iliff
G/BGS-250.235 1987
G/GC- 193.550 2021
G/GMS-182.144 2019
G/GCC- 194.580 2025
Looks to me like he also needed a lot more parachute for that one....
Numbah 10, GI !!!  :x
Liked the shot of Al early on in the video.
At 1:33, right behind the Mazda, there's Steve Batchelor's stock-bodied Monza C/CFALT that ran 243 for the record right after.  That Bonneville record and his 213 El Mirage record still stand 25 years later.
I had the very important duty of pushing him off at Bonneville.
